All of the outputs are removed right now since some were defective..
Amp is still stuck in protection mode.. Heres what i get on the 494 Pin1:0 Pin2:4.96 Pin3:.05 Pin4:4.84 Pin5:1.46 Pin6:3.64 Pin7:0 Pin8:13.04 Pin9:0 Pin10:0 Pin11:13.04 Pin12:13.04 Pin13:4.96 Pin14:4.96 Pin15:4.96 Pin16:4.96 |
#2 |
Post a photo of the inside of the amp.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Heres the pics of the board..
#4 |
Re-check the voltage on pin 16. 13, 14 and 15 may be shorted together which would account for having precisely the same voltage on those but pin 16 wouldn't be shorted to those and is unlikely to have precisely the same voltage.
#5 |
Pin13:4.96
Pin14:4.96 Pin15:4.96 Pin16:0 |
#6 |
Pin16 goes to a transistor C3198 (location Q1)
#7 |
Do you see a pulse of DC on the large output filter inductors as the amp tries to power up?
Is pin 4 of the 494 connected to the collector of a PNP transistor (possibly through a low value resistor)?
#8 |
It's likely that pin 16 is connected to ground. The protection drive is coming in on pin 4.
#9 |
If your talking about theese they both have 3.50 volts on them and the voltages remains constant..
Pin 4 connects to a C3198 (Q14) |
#10 |
DC offset must be what's shutting it down.
Post the DC voltage on all of the pins of the B52 IC. Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14:
| memphis 1500d | timwebb | Car Audio | 19 | 16th January 2011 02:21 AM |
| memphis 1500d | timwebb | Car Audio | 4 | 1st June 2010 01:23 PM |
| directed 1500d | mike49504 | Car Audio | 7 | 22nd December 2009 05:31 PM |
| mtx 1500d | mike49504 | Car Audio | 3 | 5th March 2007 01:15 PM |
| directed 1500d | mike49504 | Car Audio | 30 | 20th November 2006 01:43 PM |
| Page generated in 0.09066 seconds (77.55% PHP - 22.45% MySQL) with 11 queries |
