Directed 1500D
Directed 1500D
Old 16th June 2011, 10:57 PM   #21
mike49504 is offline mike49504  United States
They are both LM393's
Pin 1:.06
Pin 2:4.99
Pin 3:8.12
Pin 4:0
Pin 5:4.97
Pin 6:4.20
Pin 7:0.6
Pin 8:13.96
Pin 1:.06
Pin 2:13.13
Pin 3:2.90
Pin 4:0
Pin 5:3.70
Pin 6:3.23
Pin 7:0.06
Pin 8:13.96
Old 16th June 2011, 11:05 PM   #22
Perry Babin is offline Perry Babin  United States
Is there a PNP transistor with it's collector connected to pin 2 of the second comparator (via a resistor)?
If so, remove that transistor and post the voltage on the second comparator again.
Old 16th June 2011, 11:17 PM   #23
Pin 1:4.96
Pin 2:0
Pin 3:2.99
Pin 4:0
Pin 5:4.38
Pin 6:3.24
Pin 7:4.96
Pin 8:13.75
Old 16th June 2011, 11:24 PM   #24
Reinstall the first transistor you removed (driving pin 4). The amp should come on as it's doing now.
Is the last PNP transistor that you pulled defective (check it carefully)?
Is there any DC offset across the speaker terminals?
Is there any DC offset between the secondary center tap and the main ground?
Old 16th June 2011, 11:32 PM   #25
No DC on the speaker terminals..
From secondary center tap to main ground I get 2.75 volts
Old 16th June 2011, 11:37 PM   #26
Old 16th June 2011, 11:41 PM   #27
In diode check heres what i get..
1-2:OL
1-3:OL
2-3:OL
Probes reversed
1-2:OL
1-3:0.670
2-3:0.664
Old 16th June 2011, 11:44 PM   #28
It's probably OK.
Reinstall it and connect a jumper between the secondary CT and the main ground. Does that make the amp power up normally?
What's the resistance between the RCA shields and the secondary CT (no jumper)?
Old 16th June 2011, 11:58 PM   #29
On the left RCA shield to secondary center tap: 0.3 ohms
Right rca shield to center tap:0.466 K ohms
With a jumper between Secondary center tap and main ground And the transistor back in amp doesnt power up it is in protection
Old 17th June 2011, 05:28 AM   #30
You need to find the equivalent of Q270 and Q271. Finding the ones with their collectors connected together and their base and emitters connected together should make it easier. When you find them, remove them to see if they amp will power up. If it does, check each one carefully.
Directed 1500DHide this!Advertise here!
memphis 1500d timwebb Car Audio 19 16th January 2011 02:21 AM
memphis 1500d timwebb Car Audio 4 1st June 2010 01:23 PM
directed 1500d mike49504 Car Audio 7 22nd December 2009 05:31 PM
mtx 1500d mike49504 Car Audio 3 5th March 2007 01:15 PM
directed 1500d mike49504 Car Audio 30 20th November 2006 01:43 PM
Copyright ©1999-2017 diyAudio
