Directed 1500D - Page 2 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 16th June 2011, 08:19 PM   #11
Pin 1: 3.50
Pin 2: 0
Pin 3: 3.50
Pin 4: 3.50
Pin 5: 0
Pin 6: 3.50
Pin 7: 0
Pin 8: 3.42
Pin 9: 3.05
Pin 10: 3.44
Pin 11: 3.40
Pin 12: 0
Pin 13: 3.40
Pin 14:3.38
Old 16th June 2011, 08:23 PM   #12
See if the voltages are different on the inductors and the IC If you use the secondary CT as the reference (black probe).
Old 16th June 2011, 08:34 PM   #13
i must be stupid today do u know which one is the secondary center tap on the transformer?
Old 16th June 2011, 08:46 PM   #14
They are where the two center wires on the power transformer that go into the board near the yellow cored inductor.
I think you'll find that everything reads 0v. If that's the case, you'll have to remove the transistor that's driving pin 4 high, clamp all transistors tightly to the heatsink and power the amp up via a 15 amp fuse or a current limiter. There is some risk that the outputs will be damaged (I'm assuming that you've checked the outputs and none are defective as of now) but you need to get the amp to power up to find what's causing the fault.
Old 16th June 2011, 09:19 PM   #15
if i remove the transistor that connects to pin 4 the amp wont power up and the protection light goes off..
Pin 4 of the 494 the voltages pulse's up and down with the transistor removed
Old 16th June 2011, 09:21 PM   #16
Does the power supply stay on long enough (between pulses) to have a steady regulated voltage on the op-amps?
Old 16th June 2011, 09:24 PM   #17
Ok i had the wrong transistor Pulled an A1266 (Q13) amp powers up and relays kick on. Amp idles perfectly
Old 16th June 2011, 09:25 PM   #18
Does it produce clean audio?
Old 16th June 2011, 09:45 PM   #19
Yes
Old 16th June 2011, 10:35 PM   #20
If it has 2 op-amps near the power supply IC, post the DC voltage on all of the pins of each one.
memphis 1500d timwebb Car Audio 19 16th January 2011 02:21 AM
memphis 1500d timwebb Car Audio 4 1st June 2010 01:23 PM
directed 1500d mike49504 Car Audio 7 22nd December 2009 05:31 PM
mtx 1500d mike49504 Car Audio 3 5th March 2007 01:15 PM
directed 1500d mike49504 Car Audio 30 20th November 2006 01:43 PM
Copyright 1999-2017 diyAudio
