Hi I'm new here, can I say first of all how much help I have already got just from searching around this forum which is excellent, and I think I have got this mostly sussed out already, I just want to check a couple of things if anyone is kind enough to be able to help.
So, I have a Punch 60ix with power supply failure. It draws 100mA from a 12v source but that's it. There are two gate FETs which are IRFZ40s and which test as shorted (and there is some blackening around them). Also I can see what I believe are the two gate drive resistors associated with these FETs and they have gone open circuit (and they look like they got a bit hot). The rest of the board looks nice and clean (sorry no pictures at the moment, unfortunately I am typing this from work without the board in front of me). I can get replacements for these four blown components but I would like to order all the parts I am likely to need in one go. I have seen on here to check the driver transistors for the power supply FETs and the large Zener diodes near the FETs. I think I can identify the zener diodes as the two little bead shaped fellas near the transformer, but I'm not sure which are the drive transistors. I assume they will be assigned a "Q#" number on the board. I am wondering whether I should test anything else or just change any of the above which tests bad and connect the power (I have noted that I will need to connect with a suitable fuse in circuit). Also, are there any tricks for removing/replacing the FETs vis a vis the heatsink? Thanks in advance Steve |
#2 |
What's the PC-# on the circuit board?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Hi Perry, for some reason I didn't get a thread reply notification?
Anyway, the number is PC-0764-F The burnt resistor numbers are R31 and ??2, I think R32 but hard to read due to the blackening. I'm a bit confused because I downloaded a circuit diagram which says it is for a 60ix but there are four power supply FETs shown on the diagram (Q6, Q7, Q10 & Q11) and my amp only seems to have two (Q6 & Q7) ?? Another odd thing I noticed is one of the little allen screws which hold the board in has got its head missing. I can only think it was over tightened in the factory because both of the warranty stickers were intact before I opened up the amp. |
#4 |
http://www.bcae1.com/temp/rockford%2...h40i-topaz.pdf
This ^ should be close to what you have. If it's not, you can get the correct diagram from Rockford. The drivers are Q2, 3, 4 and Q5 on the diagram.
#5 |
Thanks Perry, unlike the one I found on the net that diagram actually looks like my amp. !
Re: my original post, should I test anything else before trying power up - or just change any of the components I already listed and which test bad? Also can I just share this - I didn't know this amp was bad when I bought it but in a funny sort of way I'm now actually pleased that it was broke because it means I can maybe save it. I know that doesn't make sense but somehow it just seems right. |
#6 |
You should check the output transistors to confirm that none are shorted.
After replacing all of the defective parts, clamp all transistors tightly to the heatsink and insert a 10 amp fuse in the B+ line. This will help protect the newly replaced components if there is another problem. While the power supply FETs are out of the circuit, confirm that the resistance between the B+ and ground terminals is well above 0 ohms. The meter should increase in resistance as the filter caps charge.
#7 |
Message received and understood.
It will probably take me a few days to get the parts and work through this and then I'll report back. I can't thank you enough. |
#8 |
Well, it's working
But only on one channel ![]() Hey it does sound pretty good though !! So now I just need to investigate the bad channel - I guess it helps the diagnosis with one good channel for comparison. Thanks again. |
#9 |
Hmmmm...... I can't find anything wrong. I already checked the output transistors before, but I checked them again and they seem OK. The resistors associated with them all seem OK (though my meter's lowest range is 200 ohms so not too accurate at reading around 1 ohm level).
A couple of things that I'm sure are clues to what is wrong are these: 1) if this channel is connected and I turn on the HU I get a bump from the speaker, so something is happening; 2) if I have everything else except this channel connected (I'm only testing with a low signal input) then plugging in the RCA feed to this channel shuts everything off; like it's making a short on the output, though I can't measure any difference between the channels input or output. Anyway it's half past eleven here so I think I'll give it a rest for tonight. |
#10 |
With no speaker connected to the dead channel, what is the DC voltage measured directly across the terminals for the dead channel?
| Rockford fosgate 4.6 X | mike49504 | Car Audio | 14 | 28th May 2011 03:35 PM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| Blown Rockford Fosgate 250M, help a newb =-) | mkfosgate | Car Audio | 11 | 26th July 2009 07:23 PM |
| rockford punch 60ix transistor please | ferreyrafede | Car Audio | 10 | 21st February 2007 08:37 AM |
| Rockford FETS MT75N05 | Tom7227 | Car Audio | 4 | 1st January 2007 06:53 AM |
| Page generated in 0.11480 seconds (80.27% PHP - 19.73% MySQL) with 10 queries |
