#11 |
Simple the claims of power are not possible.
There are 4 pcs of 49x19 toroids running at about 50KHz. Each is capable of 1,300w at 50KHz. This info is available from the MagInc site. So theoretically 5200w is available assuming all circuits are 100% efficient which of course they are not. The class D output stage has massive saturation issues when driving 1 ohm. The power supplies are also not 100% efficient. I repaired one of these some months ago and at 14.4v battery it delivered just under 3,000w at 1 ohm Steve Mantz Zed Audio |
#12 | |
#13 | ||
Don't worry... you can always turn the gain down! |
#14 |
@ppi, cheater amps have no place any more because there are no watt classes. SQ is still using the classes but the power itself has nothing to do with winning. SQ is all about following every rule in the code book of iasca and or db drag. The classes are done by woofer area and other criteria such as bass race which has to do with precision and longevity. The only competition that power has any play in is spl and spl classes are divided by woofer area and then by vehicle modding like extreme where you can have 6" lexan windows and cement floors.
#15 | |
SQ to me is the only real realm of audio competition nowadays in my opinion. SPL competition (in my opinion)is a joke and you could probably build a neodymium magnetized 4" thick solid 45" inch piston with no surround, connected to a 50" chamber with four non-functional wheels and a steering wheel inside with the mic mounted to it, and drive it with a 40hz sine wave from an uber high power AC inverter and call it a "test tone" with the stuff people consider music lately. :lol: Well, since my first post was referring to the OP's subject and then went into the realm of people using 16v+ alternators I'm not really arguing using cheater amps. I was just using them as examples from the past. The point I was trying to make is you can't have a relatively level "playing field" when some people have access to more expensive modifications (such as the apparently unregulated alternator voltage) some competitors utilize. If that is okay by rules then wouldn't it be okay for someone to run 1megawatt 120vac generator right next to their car and connect them with some nice thick cables, allowing them to run massive high voltage high end home amplifiers in their car with relatively low current? :lol: I mean, the guys are running modified high voltage alternators in their car that don't get used in streetable car so where does it end, why not? I'm not complaining for myself, I haven't been involved in audio competitions since the late 90's but it just seems like a simple tweek could be done to keep people from abusing rules, especially if you're going to set some arbitrary amperage limit. If you're going to create "rules", make them to apply to everyone involved.
Don't worry... you can always turn the gain down! Last edited by ppia600; 17th June 2011 at 12:07 AM. |
| PowerBass ASA 2000.10 | Dr Zeus | Car Audio | 11 | 21st December 2010 12:38 AM |
| PowerBass ASA-600.4 | audiobahnkid592 | Car Audio | 3 | 19th May 2010 09:12 PM |
| Powerbass | thunderlaxton32 | Car Audio | 1 | 27th September 2007 01:26 PM |
| TPA3120D2: Competition for your T-Amp? | theAnonymous1 | Class D | 23 | 5th July 2007 03:43 PM |
