Go Back   Home > Forums > General Interest > Car Audio
Old 14th June 2011, 05:53 AM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Sony XM-2002GTR left channel bias
I got this amp in for repair which the owner said the left channel makes a lot of distortion. Upon tear-down I found the bias is not entirely able to be set correctly; almost as if one of the drivers in this amp is leaking or having some other issue. The distortion is audible through a speaker and visible on the scope. If I set the bias to about 0.004v then about 90% of the distortion goes away, the outputs get a bit warm, and the right channel is still superior. The bad channel has three small transistors which should be the drivers: Q105, Q106, and Q107 leaning against the board's heat sync. Have not yet removed, but while on the PCB all drivers in both channels appear to be measuring the same.
Old 14th June 2011, 12:26 PM   #2
Post a photo of the distorted waveform.
Old 17th June 2011, 03:16 AM   #3
Dr Zeus's Avatar
Its the top half of the waveform with the abnormality. The scope is set to 2v/div ant 1mS. The input frequency is about 150hz sin wave. The channel that has this distortion gets a bit hotter than the one which is working fine. This is with a test speaker attached. Without the speaker the trace is thin throughout.
Old 17th June 2011, 05:31 AM   #4
Did you use exact replacements when you replaced the transistors?
Is the bias set properly?
Old 17th June 2011, 11:16 AM   #5
Dr Zeus's Avatar
I actually did not replace anything in this amplifier yet as I could not find any degraded components.
I set and re-set the bias a few times measuring the voltage from center to outer leads of the 0.22ohm two-way resistors. Ive been setting the bias to just below 0.001v at idle. If I set the idle bias to 0.004v at idle the top half of the waveform improves but outputs get pretty hot quick.
Old 22nd June 2011, 03:37 AM   #6
Dr Zeus's Avatar
I blew it. Q801 by accidentilly shorting it to the pad right next to it. All I can read o nit is ASY and possibly D1 perpendicular to the ASY. I looked up a bunch of sony schematics and Q801 almost always seems to be a 2sa1162. Is this correct?
Also, I'm still trying to figure out what is wrong with the bias on the left channel of this amp.
Old 22nd June 2011, 04:55 AM   #7
KTA1504 in SOT-23
I have the GTW serivce manual. It lists the transistor above for Q801. Email me if you want the manual.
Old 22nd June 2011, 12:40 PM   #8
Dr Zeus's Avatar
MMBT2907 (2B) looks similar and slightly superior to KTA1504. I have MMBT2907 in my collection. I'll try it out and see if I can get this amp back to the last state.
I emailed you for the service manual. Thanks!
Sony XM-2165GTX Dr Zeus Car Audio 6 6th June 2011 03:40 AM
Sony XM-GTA2022 mike49504 Car Audio 4 12th March 2011 04:05 AM
Sony XM-1004gx mike49504 Car Audio 33 26th March 2010 08:10 PM
Sony XM-4520 croccodillo Car Audio 0 14th December 2005 09:19 AM
Sony XM Radio Sawzall Digital Source 2 3rd January 2002 04:46 PM
Page generated in 0.08804 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
