I need some advice to what these part numbers are so I can replace them. One say DK QZ and the other says AG QZ. I used the smd code book and came up with bcx52 and BCX42 but not confident that is what replaces these.
The amp is also missing the LPF pot and I dont know how to start looking for a replacement. Thanks |
#2 |
I also forgot add that the parts appear to be sot89. The BCX42 part number is sot23
#3 |
The potentiometer is a quad I just need the value! Would it hurt to put a random one in like a 10k? It seems like the wrong pot would only limit my LPF range.
#4 |
Likely:
2SC4672 2SA1797 The following part may work for the crossover pot if you can't find anything else. The original was likely a 50k. 652-PTD904-2015KA203 I'd suggest that you photograph the traces under the pot before you install it. If any of the vias have been ripped out, having the photo will allow you to make the connections from the trace on the top of the board to the pins on the bottom with a jumper.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 |
Perry thanks again, I pulled the datasheets on the 2sc4672, 2sa1797 and you are absolutely right. I would like know how you knew is there a chart or something that I missed?
I replaced the missing pot with a 50k and replaced a bad zener and now it comes on and plays sounds good, but idles at 3.0 amps and one bank of outputs gets hot. I am hoping that replacing those drivers will help. |
#6 |
There are sites like the following one that help but sometimes it takes a bit more research to find the right part. As far as I know, there's no guide that is 100% accurate.
The SMD Code Book
| Hifonics amp | mike49504 | Car Audio | 10 | 5th January 2011 05:01 PM |
| Hifonics Sampson | mike49504 | Car Audio | 3 | 4th December 2010 05:26 AM |
| Hifonics | dtisme | Car Audio | 3 | 7th August 2010 12:49 AM |
| Hifonics zxi6408 | timwebb | Car Audio | 3 | 13th July 2010 04:32 AM |
| Hifonics Cupid | Lasse- | Car Audio | 3 | 5th February 2004 10:28 PM |
| Page generated in 0.08126 seconds (74.05% PHP - 25.95% MySQL) with 11 queries |
