diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Car Audio (http://www.diyaudio.com/forums/car-audio/)
-   -   Rockford Fosgate T5002 (http://www.diyaudio.com/forums/car-audio/190781-rockford-fosgate-t5002.html)
mike49504 13th June 2011 07:46 PM
The gate resistor for the output fets are 34 ohms. Wondering can i switch it to a 33 ohm?
Perry Babin 13th June 2011 07:55 PM
That would be OK but if you have to order other parts, order the correct resistors.
mike49504 14th June 2011 02:24 AM
Ok replaced all of the following in the left channel
All outputs
27.4 ohm resistors total of 4
34 ohm gate resistors total of 4
emitter resistors total of 4
and replaced all of the following resistors since they were defective
R1036
R1034
R1044
R1047
R1058
R1019
R1015
R1012
R1059
Amp power up and idles perfectly. I get clean sound on the right channel..
Left channel is very distorted and has 0.23 volts on the speaker terminals..
Cleaned all switches and bias pots are fully counter clockwise
Any ideas?
mike49504 14th June 2011 03:55 AM
OK Nevermind I was looking at the wrong channel And found the problem
Resources saved on this page: MySQL 18.75%
