Go Back   Home > Forums > General Interest > Car Audio
Old 12th June 2011, 02:19 PM   #1
Default Inphase IPA900 repair
Hello, amp is not powering up
TL494CN
1 0.6
2 2.7
3 0.05
4 0
5 1.45
6 3.31
7 0
8 11.80
9 4.60
10 4.60
11 11.80
12 11.80
13 4.87
14 4.87
15 4.87
16 0
Measured when on B+ 12V
If need - I can do macro img.
Old 12th June 2011, 03:39 PM   #2
Found few leaking diodes, one near IC 16. leg, I will replace and post with updates.
Old 12th June 2011, 06:40 PM   #3
The power supply FETs are being driven. Do you have rail voltage on the center legs of the audio output transistors?
Place the black meter probe on one of the non-bridging speaker terminals. Place the red meter probe on the point where you need to measure the voltage.
Old 12th June 2011, 07:28 PM   #4
Got 32.2V for all output transistors on center leg. No power/protection light on.
Old 12th June 2011, 08:08 PM   #5
Plus AND minus 32?
Old 12th June 2011, 08:34 PM   #6
Not sure if I understand Your question right, black probe on non bridged minus terminal, plus probe on output tranzistors center leg, all reading +32,2V
Old 12th June 2011, 09:29 PM   #7
Half should read -32. Are you missing the -32v?
Old 13th June 2011, 09:20 AM   #8
Sorry, yes, there is -32V for PNP tranzistors.
Old 13th June 2011, 09:54 AM   #9
It's working! Thanks.
Old 27th June 2011, 10:21 AM   #10
Got problems with this amp again. On ouputs was hooked blown subwoofer - like one ohm, protection lamp blinked and got turned off. Now in bridge it's burping and not playing clear audio, in non-bridge mode, it's playing audio, but not clearly and powerful as need - have noise. Where start to look first? No blown fuses.
Don't have scope, only DMM
Opamp section attached
Repair or redesign? Racket Scientist Solid State 3 30th August 2010 04:44 AM
Speaker Repair skaleth Multi-Way 6 14th December 2009 11:41 AM
sub repair...need help ! artie in miami Subwoofers 1 10th April 2009 05:55 PM
repair manuals Bryton rock Solid State 4 14th August 2008 09:19 AM
Transformer repair whitelabrat Tubes / Valves 5 2nd April 2008 03:59 PM
Page generated in 0.13963 seconds (78.38% PHP - 21.62% MySQL) with 11 queries
