Go Back   Home > Forums > General Interest > Car Audio
Old 12th June 2011, 02:05 AM   #1
Cr@sh is offline Cr@sh  United States
Default USAmps 50x REV 02 remote turn on blown
Well as the title states, I used a battery charger to power up the 50x whilst working in my garage. I didn't check that it had been set to 16v. Although this isn't a problem for the B+ input the remote can be no higher then 12v (maybe 14.4 as some vehicles charge that high) anyway it smoked two resisters.
I removed them and of course there burned so I can't determine which ones to replace with. I looked everywhere I know of for schematics and found nothing. One shows R335 and the other R235 on the board. I am new to learning electronics and I will assume that those numbers aren't actually the resistance in ohms. How can find out which ones to replace with? They were brown thanks in advance, also I searched here as well. I thought maybe there'd be a sticky on how to find out.
Old 12th June 2011, 02:30 AM   #2
More pics can be upped if needed.
Old 12th June 2011, 02:36 AM   #3
Contact US Amps to see if they can give you the value of the resistors.
Old 12th June 2011, 02:40 AM   #4
This was pre REAudio, however you may be right as they may have records of it. Thanks Perry
Old 13th June 2011, 05:17 PM   #5
Well I got an answer from Greg of RE, he said there 10ohm 1/2 watt flame resistant.
Lunar Remote Turn on issue 0ldSch00lf00l Car Audio 10 22nd November 2010 07:16 PM
Remote turn-on for power amp jwb Solid State 13 10th March 2008 09:05 AM
power amp remote turn-on wayne325 Pass Labs 2 28th July 2006 11:50 PM
Remote turn on on amp HailAngus Car Audio 2 2nd August 2005 09:40 PM
remote amplifier turn-on george a Parts 2 12th November 2002 12:15 AM
Page generated in 0.07535 seconds (75.38% PHP - 24.62% MySQL) with 11 queries
