I have 2-12" directed sx12d4's. I have three amps a ppi a600.2 a ppi a1200.2 and a lanzar optidrive 2500 which amp should i use? i can run either 4 ohm 2 ohm or 1 ohm. Thank you
#2 |
Neither of the PPI's will like a 1 Ohm load bridged and I'm fairly sure the Lanzar won't either. If it were me, I would wire the sub's coils for 2 Ohm and run any of the above amps in stereo mode (Not bridged), one sub for each channel, but to choose which one....
What amp are you planning on using for your front stage? I would use the 1200.2 on the subs wired for 2 Ohms, one for each channel like I stated above and the 600.2 for the front stage. Nothing against the Lanzar, it is a great amp but you already have the match set and I am a little biased toward those vintage PPI's.
Tools - 1. TPI Scope Plus 440 2. B&K 2125 20MHz Dual Trace 3. Sorensen DCR20-50B 4. B&K 4011 5MHz Function Generator 5. Weller WESD51 |
#3 |
I was planning on running either 2ohm stereo or 4 ohm mono. I have a 350z I don't have anything picked out yet for the front stage any suggestions on speakers or amps should I just go all art series? Thanks for the help
#4 |
Wire each woofer to series/8 ohms and parallel both woofers across the a1200.2 bridge terminals. It will be a 4ohm mono load and the amp will beat the snot out of those subs. (and sound great as well) The optidrive would also do a great job as far as power is concerned but I would go with the sq and reliability of the ppi over the lanzar. PPi for the front stage all the way
Don't worry... you can always turn the gain down! |
#5 |
Really wire them like that and the subs will hit hard. I didn't know that's why I'm asking I thought lower ohms would make the subs hit lower bass. What gauge should I run to the a1200.2 I have 2 gauge ran there now but I know it won't fit into the plugs any ideas? Thanks for your help
#6 |
You can buy the 2gauge to 8gauge step down terminals that will fit the holes in the amp plug. The optimum impedance for the a1200.2 is 2 ohms per channel in stereo or 4 ohms mono bridged. It won't put out any more power if you drop the impedance lower, it will actually cut it back some to protect the amp. If you wire each sub's coils in series it will give you 8 ohms. Then you connect both woofers to the amp and it will drop the load to 4 ohms which is perfect.
Don't worry... you can always turn the gain down! Last edited by ppia600; 12th June 2011 at 08:51 PM. |
#7 |
Ok I'll do that it won't loose any of the wire size though right
#8 |
For the ground, if the amp is bolted to metal you can just use four or five inches of the same size that fits the power terminal. For the + the step down adapter won't lose any power. You could trim the 2 gauge but it could be messy and could arc to the ground lead. They also make terminal plugs for the amp that already accept huge wire. Check ebay
#9 |
I think I will check to see if I can find a bigger plug so I can just run the 2 gauge strait to it. Any suggestions for the door speakers or amp
| Which To Choose | Feckie | Multi-Way | 0 | 25th February 2011 12:03 AM |
| what to choose?? | truttne | Full Range | 6 | 15th December 2010 06:22 PM |
| How to choose? | shmulik | Chip Amps | 17 | 1st June 2008 01:34 PM |
| What to choose?! | rinx | Multi-Way | 12 | 29th September 2007 10:23 PM |
| Help me choose please | fighi77 | Tubes / Valves | 12 | 10th June 2007 01:35 AM |
| Page generated in 0.09335 seconds (81.40% PHP - 18.60% MySQL) with 10 queries |
