when i play music on the right channel theres a noise present and the irf9640 gets warm quickly
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() the website for old rockford schematics is down right now can some one send me the schematic of this amp. sorry it's the right channel with the problem not the left as i mentioned before Last edited by stoke; 11th June 2011 at 02:12 PM. |
#2 |
gate signal q316 without speak
![]() gate signal q316 with speak ![]() gate signal q216 without speak ![]() gate signal q216 with speak ![]() gate signal q311 without speak ![]() gate signal q211 without speak
#3 |
i replaced Q321, Q322, Q324 ,Q325....... AND STILL GETTING THE SAME GATE SIGNALS OF THIS CHANNEL
#4 |
What's the PC# on the board?
This generally happens when either the bias isn't set high enough or when there is a defective output or 0.1 ohm source resistor.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#5 | |
BOTH bias are set equal and there aren't defective output or source resistor. the only thing i found is this check the pic
#6 |
I have it. Email me if you want the schematic diagram.
babin_perry@yahoo.com I don't know if you realized it but this is not a conventional amplifier. You won't see the output signal on the output transistors. The output is taken from one of the secondaries on the power supply transformer.
#7 |
#8 |
I don't know exactly why you have higher voltage but the voltage at the various points inside the feedback loop will vary to whatever they need to be to produce a clean output signal.
Is the output clean or distorted from this channel? Is the bias control on this channel working properly? Don't try adjusting it without having the transistors clamped to the heatsink.
#9 |
ok, i have the transistor clamped to the heatsink, now how i know that bais control is working properly when im adjunsting it
#10 |
The idle current will increase as the transistors become bised on.
| Rockford Fosgate Power 1000a2 | seankane | Car Audio | 31 | 6th April 2011 04:23 AM |
| rotel RA-311 left channel noise | mogga | Solid State | 3 | 26th February 2011 08:17 AM |
| help with some Left Channel Noise... | vandalfsens | Solid State | 3 | 27th October 2010 03:57 PM |
| NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) | stoke | Car Audio | 6 | 1st October 2010 10:21 PM |
| Crackling noise in left channel. | fritz39 | Solid State | 1 | 20th January 2009 11:57 PM |
| Page generated in 0.11439 seconds (83.16% PHP - 16.84% MySQL) with 10 queries |
