Go Back   Home > Forums > General Interest > Car Audio
Old 11th June 2011, 04:39 AM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Nakamichi PA1004
I've got this amp needing new output fets in one of it's four channels; which are IRFZ34N. Would I be able to sub something in close range to it like an IRF530, IRF540 or IRFZ44N? IRF530 and IRF540 seem very close.
The amp is using 22ohm 1/8w gate resistors and 0.1 ohm resistors. Whats kind of strange about this amp is that is appears to be manufactured with some of the source resistors removed by design such as R230. its like this on all channels but the other channels are working OK.
Old 11th June 2011, 06:04 AM   #2
MOER is offline MOER  United States
Default PA1004
Dr. Zeus,
I designed these amps. Use IRF540N or similar and they will work fine BUT you must replace all FETs in a channel if you change.
Used parallel FETs with common source resistors
Careful on setting the bias, FETs go up in smoke if you over bias them
Steve Mantz
Zed Audio
Old 11th June 2011, 08:11 PM   #3
ppia600 is offline ppia600  United States
Don't worry... you can always turn the gain down!
Old 13th June 2011, 02:36 PM   #4
Dr Zeus's Avatar
Old 13th June 2011, 11:14 PM   #5
What was the reasoning behind the random resistor and jumper setup, did he ever tell you? (why I reposted the pic)
Nakamichi pa1500 Alexander80 Car Audio 0 10th January 2010 08:35 PM
Nakamichi Gear Oldskool Pass Labs 0 27th March 2009 04:56 PM
nakamichi Amplifier1 lalaina Solid State 0 27th June 2006 08:15 AM
Nakamichi AV3S ? v1d9uy Digital Source 4 25th January 2006 05:42 PM
Nakamichi with Alzheimer’s troystg Solid State 7 25th November 2005 03:03 AM
Page generated in 0.06924 seconds (84.80% PHP - 15.20% MySQL) with 10 queries
