Go Back   Home > Forums > General Interest > Car Audio
Old 9th June 2011, 11:30 PM   #1
Default Rockford fosgate 550x
I replaced the outputs in 2 of the channels. Also replaced the following transistors
Q105
Q106
Q112
Q113
Q114
Q115
Q116
Q117
I also checked all the 10 ohm gate resistors on the outputs i replaced.
Amp still draws excessive current But when i remove the outputs out of the 2 channels that were bad the amp powers up perfectly..
Any ideas?
Old 10th June 2011, 12:22 AM   #2
seankane's Avatar
Do you have any DC on the output bridging terminals?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 10th June 2011, 12:25 AM   #3
seankane's Avatar
I am sure you have some faulty smd resistors and smd bjt's. I dont have a schematic but have a similair 4 channels amp I had the same issues with and was able to figure it out.
Old 10th June 2011, 03:10 AM   #4
Ok got the excessive current draw to go away..
Wondering what 2 transistors i pull to see if the distortion goes away on 1 channel?
Old 10th June 2011, 03:28 AM   #5
Bias pots fully CCW?
Old 10th June 2011, 03:32 AM   #6
Yes I get distortion is only 1 channel other 3 channels work perfectly..
I cleaned all switches and pots
Old 10th June 2011, 03:37 AM   #7
What series parts are in the distorted channel?
Old 10th June 2011, 03:39 AM   #8
200 series
Old 10th June 2011, 03:44 AM   #9
Can you post an image of the distorted waveform with a speaker load?
Old 10th June 2011, 03:47 AM   #10
Ill have to wait on that for a lil bit havent got to the store yet to buy another camera
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford fosgate 550x mike49504 Car Audio 1 11th February 2011 12:30 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Power 550x bias issue brandes.cm Car Audio 5 24th November 2009 01:13 PM
rockford fosgate 550x mike49504 Car Audio 21 6th December 2008 10:26 PM
Page generated in 0.09668 seconds (78.08% PHP - 21.92% MySQL) with 10 queries
