I blew a left amp channel. It sounded like my left front door speaker had blown out. There was a loud pop - then no sound on the left side. The right side plays normally and the amp comes on with no issues other than no sound on the left side.
I opened up the amp and visually inspected it for signs of burned parts or smell but nothing was discovered. How do I proceed? Thanks. |
#2 |
Is there any DC voltage on the speaker terminals of the blown channel (measured directly across the speaker terminals)?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
-9.28 V DC.
#4 |
Upon a closer look I noticed that there is a "Right" and "Left" daughter board. On the Right Channel daughter board, pictured on the left, there is ONLY one lighted-type surface mount device and it is lit GREEN as in the picture.
However, on the right side of the picture which is the Left Channel, there are THREE lighted-type surface mount device and they are all lit GREEN in the picture. |
#5 |
Check the 10 ohm resistor near the second pin from the left.
#6 |
It reads 10 Ohm's.
#7 |
The 47k ohm resistors (large, marked 473) are known for bad solder connections. Check the connections. They typically need to have new solder added, be desoldered and re-soldered to remove the oxidized layer of solder.
#8 |
One reads 46.79k Ohm's
Other reads 46.85k Ohm's. How do I go about desoldering/re-soldering a surface mount resistor? Do I need a special tool to do this? |
#9 |
You don't need 'special' tools but you'll need desoldering braid (liquid or paste flux if the braid isn't good quality - radio shack paste flux is messy but works well enough), solder and a soldering iron.
Do one end of the resistor at a time and you won't have to worry about getting it positioned properly on the solder pads. There's no guarantee that this will solve the problem but it's a common enough problem that you need to do this before you do any more troubleshooting.
#10 |
Okay, I will do the above, however.
While waiting for a response, I did some resistance checks. There is a 621 resistor that reads 16.47M Ohm. Using a lighted magnified, I discovered that that value is slightly defaced, probably caused by smoke. Nothing on the board is burnt. I couldn't see this with my naked eye. A comparison of the right channel of resistor 621 reads .619k Ohm - being in tolerance. What other component would have failed, causing the resistor to burn open? A shorted diode, maybe? I figured it would have been a resistor problem as I 'scoped the amp last night via the TP1 and TP2 and noticed TP1 had a nice waveform with adequate amplitude and TP2 had a minutely small waveform, slightly above dc. |
| low audio on left channel jvc vn-300 | stevodude | Solid State | 5 | 22nd February 2011 07:56 AM |
| JL 300 sub 2 channel amp...and a stinky smell | aptquark | Car Audio | 2 | 25th September 2010 08:54 PM |
| JL Audio 10w6v2 or Infinity Kappa 100.3se? Audison SRX4 or Jl 300/4? | DcMaN | Subwoofers | 1 | 17th September 2010 10:28 AM |
| Blown left channel | m3brooklyn | Tubes / Valves | 0 | 30th May 2010 03:46 AM |
| Marantz 1060 Blown Left Channel | barako | Solid State | 1 | 27th July 2007 12:07 PM |
| Page generated in 0.10582 seconds (77.87% PHP - 22.13% MySQL) with 11 queries |
