Help With ppi A1200.2
Hey i'm new to the community this is my first post but im not new to electronics. I need help identifying a resistor that is bad its burnt and i cannot read the color code. If someone is out there that can help i would be gladly appreciated. It is resistor 39 if you can't tell the coating has burned off. Thanks for the help. Here are some pictures. Thank you Attached Thumbnails Hey i'm new to the community this is my first post but im not new to electronics. I need help identifying a resistor that is bad its burnt and i cannot read the color code. If someone is out there that can help i would be gladly appreciated. It is resistor 39 if you can't tell the coating has burned off. Thanks for the help. Here are some pictures. Thank you
#2 |
I have this amp labeled as an a1200.1 but it appears to be the same. If so, it's a 2.2 ohm resistor.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Wow great thank you so very much i will grab one from work tomorrow and try it. Perry your amazing thank you again
#4 |
Thank you for that Perry works like a champ now.
| Need Schematic for PPI A1200.2 | integrite07 | Solid State | 3 | 8th June 2011 09:47 PM |
| Help With ppi A1200.2 | integrite07 | Solid State | 2 | 4th June 2011 01:01 PM |
| PPI A1200 | mike49504 | Car Audio | 49 | 26th October 2010 01:13 AM |
| Ppi a1200 | amc32 | Car Audio | 1 | 8th February 2010 07:31 PM |
| Profile A1200 XL Odd Power Supply | amc32 | Car Audio | 5 | 26th November 2008 10:44 PM |
| Page generated in 0.08340 seconds (75.21% PHP - 24.79% MySQL) with 11 queries |
