#21 |
Did you try pulling the center leg on the rectifiers to see if that reduced the current draw?
Do one at a time if you haven't done this already. Are any of the transistors or rectifiers heating up? Are the outputs still out of the circuit?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 | |
Only one channel has the output fets still in place the other channel has them removed, and there are no solder bridges. None of the remaining output fets seem to be getting hot nor do the rectifiers. So when I try to power up with the center leg removed of the rectifiers (one at a time) I should have the current limiting resistors not in line with the B+??
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#23 |
Yes.
#24 |
Powered up with center leg of CR2 removed and result was the amp would not power up.
Powered up with center leg of CR1 removed and result was the amp powered up fine and seem to have no issue. Wierd??
#25 |
Was CR2 back in the circuit when you disconnected CR1?
#26 |
YES
#27 |
If CR1 isn't leaking, I'd suspect a rail cap.
With NOTHING hooked to the amp, touch the 12v power supply across each of the rail caps (observing proper polarity). Does any cap cause any current flow after the initial charging?
#28 |
The 3 on the CR1 side seem fine, but the 3 on the CR2 side arc pretty good when you apply power but none of them seem to be making my power supply draw current.
I removed one cap from the CR2 side and put power to it out of the circuit and it seemed fine holding 13.87 volts and slowly bleeding down. Thinking CR2 is defective?
#29 |
I doubt that CR2 s defective if it powered up normally with it in the circuit.
Solder the legs for the rectifiers back to the board and disconnect the input legs of the voltage regulators. Does that reduce the excessive current draw?
#30 |
I will try it.
Meanwhile I removed all the rail caps, and powered up the amp. It does not draw alot of current, but is a very choppy draw quickly pulsating up and down from 0 amps to 3 amps. Shall I re-install the rail caps and try the voltage regulators next? Can I power up the amp with the V/R input legs removed and the rail caps removed?
| Rockford Fosgate Punch 800a4 | seankane | Car Audio | 7 | 20th June 2011 07:15 AM |
| Rockford Fosgate Punch 200IX | seankane | Car Audio | 64 | 12th May 2011 12:48 AM |
| Rockford Fosgate Punch 30 | warpedhifi | Car Audio | 2 | 9th November 2010 04:28 PM |
| rockford fosgate punch z | stevena2006 | Car Audio | 2 | 23rd December 2009 04:20 PM |
| rockford fosgate 500s | mike49504 | Car Audio | 14 | 20th October 2006 06:04 PM |
