Hello everyone.
I recieved a Rockford Punch 800a4 in for repair. 2 channels were completely fried. I rebuilt both channels and all is well, good clean output on the scope and great solid sound. The problem is when you switch the input switch from 2 channel to 4 channel input the amp makes a loud pop. I replaced the switch with a new switch with same result. I am wondering if this is normal?? I dont think it should do that. The amp works great but its like something is goofy with the input and crossover switches. Any ideas would be great...............Thanks again.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#2 |
I wouldn't use the switch with the amp on, sounds normal to me.
Don't worry... you can always turn the gain down! |
#3 |
That's generally caused when one of the op-amps has significant DC on its output. Compare the DC voltage on the output terminals of the op-amps feeding the switch.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#4 |
No significant difference, all the op-amps read the same.
Pin 1: 0.635 vdc Pin 2: 0.735 vdc Everyone on the board reads the same. I checked these with no signal present, wondering if I should check them with a signal present????
#5 |
It appears that you don't have the signal source ground connected to the amp's 12v power supply ground. Are they connected?
#6 |
Signal source unit? I have the head units ground connected to the same ground as the amps ground. These tests were done with no signal present. I re-tested with the rca's (signal) hooked up and the readings were almost all at 0.000 vdc on pins 1 and 7 of all the op-amps. Just a fraction of a volt on a few but no substantial dc, nothing over 0.015 vdc.
Any other ideas of why the switch would pop through the speakers upon being switched from 2 channle to 4 channel input???
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch Last edited by seankane; 20th June 2011 at 05:50 AM. |
#7 |
If the switch is 'break before make', it could be creating an open circuit for a fraction of a second which could cause a tiny bit of instability.
#8 |
Well thats probably what it is cause the old switch and the brand new switch do the same thing. The amp works perfect other than that so I wont sweat it.
Thanks Perry.
| Rockford Fosgate Punch 200ix | seankane | Car Audio | 2 | 4th June 2011 01:02 AM |
| Rockford Fosgate Punch 200IX | seankane | Car Audio | 64 | 12th May 2011 12:48 AM |
| Rockford Fosgate Punch 400a4 | seankane | Car Audio | 62 | 14th April 2011 06:38 AM |
| Rockford Fosgate Punch P325.2 | mbates14 | Car Audio | 2 | 25th November 2010 03:11 AM |
| rockford fosgate punch z | stevena2006 | Car Audio | 2 | 23rd December 2009 04:20 PM |
| Page generated in 0.08859 seconds (76.03% PHP - 23.97% MySQL) with 10 queries |
