Go Back   Home > Forums > General Interest > Car Audio
Old 7th June 2011, 08:22 PM   #1
otto88's Avatar
Default How’s this domestic woofer for a small hatch’s boot?
Its a good price, and good quality, for a
• Nominal impedance: 8 ohms
• Power nominal: 225 WRMS
• Sensitivity: 91 dB
• Qts: 0.32
• Vas: 22 litres
• Fs: 60 Hz
http://www.jaycar.com.au/productView...r&form=KEYWORD
in Unibox it models into 300 litres (my estimate of the boot's size), vented at 80 Hz, with a nice +4 dB bump up at about 80 Hz, for some thump factor
How would an 8 ohms driver work with a normal car 4 ohms amp?
a system that won't go clean and loud is like a nice car that cannot go fast
Old 7th June 2011, 08:27 PM   #2
half the power. aka if the amp put out 200 watts at normal 4ohms, it would only put out 100 watts at 8ohms.
Old 7th June 2011, 08:32 PM   #3
otto88's Avatar
Yes, so as long as I have enough power (halved) to get to my target SPL (which is only peaks of about 106 dB) . . .
And if I ran 2 * car co-axial 6.5", 4 ohms car speakers off two amp channels; and two 8 ohms woofer off the other 2 channels . . ?
Old 7th June 2011, 08:49 PM   #4
sofaspud's Avatar
The 4 ohms and 8 ohms are nominal values; in use the impedances are going to vary with frequency. In general, using a higher nominal value as an amp load is alright. In your case, you'll likely want a means of "balancing the front & rear outputs", ie a fader. I'm not sure if you plan to do that at the head unit, amp, or the speakers.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 7th June 2011, 09:03 PM   #5
otto88's Avatar
Thanks SS, I follow you
I'll make sure there's a fader in the head unit
Cheers
Old 8th June 2011, 12:55 AM   #6
ppia600 is offline ppia600  United States
You can bridge the amp's rear two channels into one and parallel the two 8 ohms woofers across the one bridged channel to maximize the amp's output. Then run the front speakers on the amp's front channels. The amp should easily be able to handle a 4 ohm load bridged if its anything decent made within ten years or so.
Don't worry... you can always turn the gain down!
Old 8th June 2011, 03:29 AM   #7
sofaspud's Avatar
...which means a 2 ohm load for the amp. My own approach is to not stress the amp unless the mfr spec'd it for low-ohm loads. YMMV.
Old 9th June 2011, 07:05 PM   #8
otto88's Avatar
Thanks guys, will give it a try
So how much power do you really need for domestic listening ? Mooly Solid State 222 24th November 2011 10:04 AM
Very Small Woofer solidfooting Full Range 40 25th May 2011 01:43 AM
a sinergy horn for domestic use angeloitacare Multi-Way 14 16th January 2009 04:45 PM
Small Sub Woofer scottjr Subwoofers 8 18th January 2008 04:08 PM
very small woofer neutron7 Multi-Way 7 25th July 2007 04:27 PM
Page generated in 0.08751 seconds (87.01% PHP - 12.99% MySQL) with 10 queries
