Go Back   Home > Forums > General Interest > Car Audio
Old 7th June 2011, 04:49 AM   #1
Dr Zeus is offline Dr Zeus  United States
Dr Zeus's Avatar
Default Alpine MRV-F300S
Got this amp in for repair. I noticed some connection problems under the PCB for the RCA and fixed. Upon power applicaiton, the amp appears a slight attept at powering up but fails and powers off no more than 1/4 second later. Measuring with the scope I see the amp pulse a +10v wave at the fets. I can also observe a very brief ~+-60vDC on the center legs of the rectifiers. I'm guessing this amp is tethering in/out of protection as several pins of the TL494 pulse every ~4 seconds
Old 7th June 2011, 04:51 PM   #2
Do you see a pulse of DC on the bridging speaker terminals of any channel as the amp goes in/out of protection?
Old 8th June 2011, 04:12 AM   #3
Dr Zeus's Avatar
There is something wrong with chanel 2 (This is a 4 channel amp) where I can observe a +-20v severely clipped sine wave with no signal input to the amplifier. The outputs for channel 2 are Q211 and Q212 and they are not measuring shorted.
Old 8th June 2011, 04:30 AM   #4
Dr Zeus's Avatar
i just found C205, a yellow mylar cap near some of the opamps with a bad solder joint which I just fixed. Now I cannot get channel 2 to pulse anything on the scope more than just insignificant DC. All channels have +-.2vDC of pulsing activity on them. Amp still power cycles like before.
Old 8th June 2011, 12:51 PM   #5
Dr Zeus's Avatar
TL494
Pin 1: 0
Pin 2: 0.882
Pin 3: 0.090
Pin 4: 4.97 (Drops to ~2.5-3v every ~4 seconds)
Pin 5: 1.684
Pin 6: 3.738
Pin 7: 0
Pin 8: 13.74
Pin 9: ~0 (Pulses to .5v)
Pin 10: ~0 (Pulses to .5v)
Pin 11: 13.74
Pin 12: 13.74
Pin 13: 5.05
Pin 14: 5.05
Pin 15: 5.05
Pin 16: 0.001
Old 8th June 2011, 01:54 PM   #6
Dr Zeus's Avatar
When pulsing, the center leg of Q509 (a 5KF10P20FR) hits -40vDC momentarilly. On the other hand, Q508 (a 5JF10P20F) only hits about 12vDC before rocketting back to 0v.
Old 8th June 2011, 02:46 PM   #7
Dr Zeus's Avatar
Referencing amp general ground pulse of -15vDC is on all speaker terminals. Referencing RCA shields I see no more than about -0.150vDC on speaker terminals. Referencing non-bridging speaker terminals or RCA shields I see +-20vDC on the center legs of the main rectifiers; D508 D509. Also I meant to say D508/D509 in my previous post, not Q.
Old 8th June 2011, 03:10 PM   #8
Can you post a photo of the inside of the amp. I have no information on this amp.
In general, there is an isolation between the primary and secondary grounds. When the secondary ground is pulled away from the primary ground, the problem is often a protection circuit component. Typically it's a PNP transistor with it's emitter connected to the positive rail (or sometimes to 5v) and it's collector connected to something near the power supply IC. You may have a problem like this.
Old 8th June 2011, 03:34 PM   #9
Dr Zeus's Avatar
I like the "army" of opamps.
Old 8th June 2011, 03:41 PM   #10
Dr Zeus's Avatar
Heres some pictures of the back of the PCB where identifications are easier to read.
Alpine MRV-F400 DJDestiny Instruments and Amps 0 2nd April 2011 12:07 PM
Alpine MRV-1507 Dr Zeus Car Audio 15 2nd March 2011 11:17 PM
Alpine MRV 1507 FSUSeminole Car Audio 8 1st January 2011 07:04 PM
Alpine MRV T500 mk2singh Car Audio 0 11th December 2010 10:47 AM
Alpine MRV-F401 or MRV-F400 Service Manual M.André Car Audio 6 21st February 2010 09:37 PM
Page generated in 0.10383 seconds (80.07% PHP - 19.93% MySQL) with 10 queries
