Go Back   Home > Forums > General Interest > Car Audio
Old 6th June 2011, 06:14 PM   #1
Default phonics digital 397 volts on output
I am getting -11v on the -speaker bridge terminal.This is happening when i turn the gain all the way up.could this be a bad opamp in the input section?
Old 6th June 2011, 06:34 PM   #2
It could be a defective op-amp. Do any op-amps have more than ~0.01v DC on their output terminals?
Old 6th June 2011, 06:56 PM   #3
i am geting +8.8v on pin 7 on one of the opamps.It also looks like the gain port is connected to it.In my first post i said there is volts when the gain is up but it is when the gain is down.
Old 6th June 2011, 06:59 PM   #4
Post the voltage on all pins of that op-amp if you haven't replaced it yet.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 6th June 2011, 07:26 PM   #5
yes i already change the opamp but still same problem.so i also change the gain port and there is no volts now.I never thought a gain port could cause a problem like that.I will mount it back to the sink to test for audio
thanks
Old 6th June 2011, 07:44 PM   #6
If the pot was in the feedback loop for the gain circuit and there was an open connection between the pot and the op-amp (could be internal to the pot), that could cause a DC offset.
+ volts on my -output and -volts on my + output ford06f150 Car Audio 20 8th June 2011 03:29 PM
Any digital modules that can use +/- 74 volts digital desire Class D 1 26th April 2009 05:22 AM
Yamaha RX-397 schematic? zener_diode Solid State 4 10th January 2008 10:35 PM
High DAC Output Voltage (2.7 Volts) john65b Digital Source 4 29th December 2006 09:23 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 12:10 AM
Page generated in 0.08777 seconds (76.09% PHP - 23.91% MySQL) with 11 queries
