Stumped on RF Punch 100 DSM amp - help
Old 17th June 2011, 12:16 AM   #71
m109ner is offline m109ner
Mistake...Gains are set counterclockwise (low).
Old 17th June 2011, 12:58 AM   #72
With Gains full clockwise (Max):
both RCA channels = 1.7VAC
#12 = 1.7V AC
#17 =9.54V AC
#18 = 8.32V AC
#8 = 1.7V AC
Old 18th June 2011, 12:18 PM   #73
I woud really appreciate/welcome anyone's assistance.
thank you kindly
Old 18th June 2011, 06:36 PM   #74
Perry Babin is offline Perry Babin  United States
Post the DC voltage on all 3 legs of Q101 and the DC voltage measured directly across R103.
Old 18th June 2011, 10:38 PM   #75
All readings in DC Voltage with amp powered up with no audio source.
*R103 = -15.10, -14.85
*Q101
2 legs on same side = -15.10 and -14.85
1 leg by itself =-15.09
Old 18th June 2011, 11:48 PM   #76
Measure the AC voltage across the speaker terminals for both channels.
Measure the AC voltage with one probe on pin 1 of the audio driver board and the other probe on pin 2 of the audio driver board. These are the boards near the output transistors. Post the voltage for each driver board.
Old 19th June 2011, 01:31 AM   #77
with and w/o audio measurements in AC voltage:
Speaker terminals
R Channel
+=3.5mV
- =starts at 3.5mV and goes all over the place
Left Channel
+=3.5mV
- =3.5mV
both audio driver boards
R Channel
+=3.5mV
Left Channel
+=3.5mV
- =3.5mV
Getting static out of right channel speaker for the first time.
Old 19th June 2011, 01:41 AM   #78
With the black meter probe on the main ground terminal, post the AC voltage on both terminals or C102 and C103. It's likely that these capacitors are defective (along with all of the 10uF SMD caps in the amp). Do this with the 1v input signal.
Stumped on RF Punch 100 DSM amp - helpHide this!Advertise here!
PUNCH 4080 DSM bdgf2004 Car Audio 4 21st March 2011 07:45 AM
punch 40 dsm bdgf2004 Car Audio 10 11th January 2011 12:03 AM
Rockford punch 100 dsm mike49504 Car Audio 1 13th December 2009 12:41 AM
punch 100 dsm question ben04srt Car Audio 32 7th December 2009 12:38 AM
another punch 100 dsm issue ben04srt Car Audio 17 20th March 2009 02:09 AM
