#21 |
Only half of those are the rail voltage. This amp uses all N-channel outputs so the positive rail is on the center leg of half of the outputs and the negative rail is on the third leg of the other half of the outputs. The output stage seems normal with only 8mv of offset.
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 |
damn, just started popping fuses - 15, 20, 30 amp fuses. ????/
#23 |
Don't use anything larger than a 10 amp fuse when testing this amp.
#24 |
OK. BUt wouldn't a 10amp fuse blow if the others blew?
#25 |
No blown fuses until i started testing pins 8 & 12 of the LM339D chip. hmmmm???
#26 |
You need to find the fault, not use larger fuses. You likely have a shorted output transistor. After you find the fault and repair it, use a 10 amp fuse.
I'm assuming that you didn't turn the bias pots.
#27 |
The preamp module is the board behind the RCA jacks.
#28 |
nope. they've been the same as when I opened the amp. Each are at about 10 o"clock position clockwise.
On the amp, how do i test which one is bad with a MM? |
#29 |
Read the basic amp repair page (link in sig file).
#30 |
| PUNCH 4080 DSM | bdgf2004 | Car Audio | 4 | 21st March 2011 07:45 AM |
| punch 40 dsm | bdgf2004 | Car Audio | 10 | 11th January 2011 12:03 AM |
| Rockford punch 100 dsm | mike49504 | Car Audio | 1 | 13th December 2009 12:41 AM |
| punch 100 dsm question | ben04srt | Car Audio | 32 | 7th December 2009 12:38 AM |
| another punch 100 dsm issue | ben04srt | Car Audio | 17 | 20th March 2009 02:09 AM |
