Product 3
![]() Got this little amp in for repair. The owner said it may be made in Louisianna. The board is stamped, "Designed and drawn by K.Lanclos Q.A.S. Opelousas, LA. There are also some fun things written on the board, like "Secret Circuit Under Caps" and, "What Does This Do" under the 50v rail caps. ![]() ![]() The amp uses 6x IRF3205 in the PS, and 45N20B outputs. When powered, sometimes the amp will will produce +-44vDC rail voltage. If let for sitting, eventually the amp will just go into protection (red LED) and the rail voltage drops to practically nothing. There is nothing visually out of wack other than a 1/2w 6.8k good reading but darkened resistor pictures near the red LED which likes to run hot. The voltage across this resistor while the amp is powered and NOT in protection is ~86vDC. While the amp is powered and not in protection there is observed AC signal output proportionate to what is inputted from my frequensy generator; however the signal is very very weak, dirty audio, and only slightly more amplified at full gain than measuring my frequency generator directly with the o-scope. |
#2 |
I found out that 1/2 burnt resistor is mainly just going to the amp's primary power LED. I'm sure it is just being used to supply the proper voltage off the rail to the power LED.
#3 |
Yeah those amps were made in Louisiana, I remember some guy bragging about his two channel. It was pretty small and had the hammered metal finish. Don't know if they were worth anything, never heard one play.
Don't worry... you can always turn the gain down! |
#4 |
remove the outputs and let it idle.one might be leaking
#5 |
I figured out why the amp sometimes goes into protect; its like it senses my meter probes and freaks out.
I do think I found a problem with either the primary opAmp or something around it. Unless this opAmp is being used as something else, the outputs are not totally up to par. Referencing the amp's CT, the LF347N is getting +-15.2vDC at power pins. Two of the four outputs are measuring 14.4v. A third output is measuring 0.250vDC, and the last is measuring -0.060vDC. I think I want to at least pull this opAmp out this to check out what reads then. http://focus.ti.com/lit/ds/symlink/lf347b.pdf I have a few spare quad opAmps; LM324N and LM837N. Worth testing with? |
#6 |
Post the voltage on the pins.
Pin 1: Pin 2: Pin 3: Pin 4: Pin 5: Pin 6: Pin 7: Pin 8: Pin 9: Pin 10: Pin 11: Pin 12: Pin 13: Pin 14:
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#7 |
LF347N quad opamp
Pin 1: -0.274 Pin 2: -0.014 Pin 3: 0.000 Pin 4: 15.45 Pin 5: -0.274 Pin 6: -0.076 Pin 7: -0.067 Pin 8: 14.88 Pin 9: 14.88 Pin 10: 14.34 Pin 11: -15.54 Pin 12: -0.048 Pin 13: 15.40 Pin 14: 15.40 |
#8 |
The section with pins 12, 13 and 14 is defective unless something is driving DC back into the output of the op-amp.
#9 |
I couldnt find much sense in why pins 14&15 had ~15v on them (other than because they were tied directly together) so on a hunch I clipped the pins off the side of the opAmp which detached them from the PCB. Now I read the following:
LF347N quad opamp Pin 1: -0.474 Pin 2: -0.027 Pin 3: 0.000 Pin 4: 15.45 Pin 5: -0.474 (tied to Pin 1) Pin 6: -0.114 Pin 7: -0.100 Pin 8: -14 *See below Pin 9: -14 *See below Pin 10: -0.003 Pin 11: -15.54 Pin 12: -0.048 Pad 13: -0.003 Pad 14: -0.003 Pin 8&9 are connected. When I first touch my meter to them, I read ~-0.3v, but after ~4 seconds the voltage drops to -14v. If I release and re-apply meter, it demonstrates the behavior again. This was not the case before clipping Pin 13&14. I went ahead and also clipped Pin 12 and the above made no difference. Im tempted now to clip Pins 8,9,10... |
#10 |
OK Looks like the amp really did just have a bad opAmp. I still need to replace it, but I am now able to get some full volume audio out of this amp (With pins 12,13,14 clipped) and a test speaker attached. It has a wicked whining coming through but at least I've made progress.
| Lunar Remote Turn on issue | 0ldSch00lf00l | Car Audio | 10 | 22nd November 2010 07:16 PM |
| Lunar amplifiers? | damage | Car Audio | 1 | 20th June 2010 12:56 AM |
| FS: Lunar L100x2 & L40x2 Amplifiers | omarmipi | Swap Meet | 3 | 4th December 2008 04:43 AM |
| Great Lunar Eclipse tonight | Pano | Everything Else | 11 | 28th August 2007 08:38 PM |
| Page generated in 0.09495 seconds (86.83% PHP - 13.17% MySQL) with 10 queries |
