ok so i rebuilt the driver card and it powered up good for a few minutes.then these two resistors smoked between q110 and q11.
#2 |
Were the output transistors in the circuit?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
no all transistors were out.
#4 |
That may have been the problem. With the outputs out of the circuit, the transistors connected to those resistors were likely driven on hard to compensate for DC on the output terminals (could have been only millivolts). That could have caused the resistors to overheat.
#5 |
i just replaced all the transistors on the board. im trying to save transistors cause they exploded the last time i put some in.
#6 |
Were you using a current limiter when they exploded?
Which ones exploded?
#7 |
i used a 10amp fuse.and the output transistors keep popping. im not seeing a wave on any of the gate resistors for the out puts.
#8 |
This is a self oscillating amp. You won't see any oscillation with the outputs out of the circuit.
Do you have a large 2 ohm current limiting resistor?
#9 |
no i dont have any on hand.
#10 |
Either buy a 2 ohm 100 watt tubular ceramic resistor (~$10) from digikey or mouser or go to Radio Shack and buy four of the 8 ohm 20 watt resistors and wire them in parallel to make a 2 ohm resistor. A current limiter won't save parts in all instances but they will easily pay for themselves in just a few repairs.
| power bass 1500 | timwebb | Car Audio | 15 | 29th May 2011 07:11 PM |
| Help reqd - power bass for PA use | mhtplsh | PA Systems | 19 | 16th September 2010 02:38 AM |
| Big bass from small power | johnr66 | Subwoofers | 6 | 5th March 2010 03:40 PM |
| bass preamp and power amp | superseadragon | Solid State | 1 | 13th July 2007 06:23 PM |
| Bass power | nag1_uk | Everything Else | 10 | 28th April 2005 01:58 PM |
| Page generated in 0.09117 seconds (76.54% PHP - 23.46% MySQL) with 11 queries |
