600w 4ch fronts work just fine but rear is distorted and im geting +volts out the roght and nagative volts out the left. to brige it i have to hook to both plus spots. output Transistor test good no shorts on any post.any help thanks shaun
#2 |
Make and model of the amp?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
sorry its a jensen power jpa460
#4 |
Post a photo of the inside of the amp.
#5 |
#6 |
How much positive and negative voltage do you have on the defective channels?
With the amp off, find the transistors in the amp that read 0 ohms between their third legs and the terminals with the DC voltage on them. Which transistors are they in the photo?
#7 |
so u mean from output transistor to srews where speakers lookup. check positive and negative speaker spots? when u say what's + - volts channels do I need to check it both ways +on+ -on- and reversed +on- -on+ thanks
#8 |
On the terminals where you determined that there was too much DC voltage, place one probe on the terminal and probe the third legs of the output transistors until you find the transistors that are directly connected to the terminals (~0 ohms).
Please use complete sentences, capitalization and punctuation. it's difficult to understand what you're asking.
#9 |
Ok sorry about that. Well i get 1.40 volts on the left ch and -1.30 volts on the right ch with audio hooked to the amp. I get .06 left ch -.06 right ch with out audio hooked to the amp. Its not a matter of too much. I get a negative voltage on the right ch. When i hook my probes up backwords to get positive voltage. in order to brige it i have to hook to both positive ports. Thanks Shaun
#10 |
Using the two rear positives isn't bridging.
What happened when you tried bridging it LR+ to RR-? Do you have a better camera? Better photos would make it easier to help.
| I need 15 volts regulator from 40 volts DC | sunny | Power Supplies | 23 | 31st May 2011 07:52 PM |
| DC heater voltage 6 volts or 12 volts? | speakerfritz | Tubes / Valves | 7 | 8th October 2010 03:59 PM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 02:52 PM |
| High DAC Output Voltage (2.7 Volts) | john65b | Digital Source | 4 | 29th December 2006 09:23 PM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 12:10 AM |
| Page generated in 0.09479 seconds (77.19% PHP - 22.81% MySQL) with 11 queries |
