Hello everyone.
I have a Rockford 200ix that I am repairing. This post is directed mainly towards Perry. I have a question concerning the parallel outputs must match discussion we have had in the past. The power supply was fried and one output fet was shorted. I repaired the power supply and all is well with that. I replaced the bad output fet and the amp plays audio and sounds great with no issues. Since this amp uses all IRF540's in both channels would these be considered parallel outputs? Do all the output fets in the repaired channel need to match the replaced fet? Does the other channels IRF540's have to match the repaired channel as well?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#2 |
There are 6 outputs per channel. That means that there are 2 sets of 3 parallel transistors. Three reproduce the positive half of the waveform. The other three reproduce the bottom half of the waveform. If one failed, you need to (at the very least) replace the two that were in parallel with the one that failed. For better reliability, I'd suggest replacing all in the channel. This doesn't have anything to do with parallel operation. If one failed, all in the channel were likely driven very nearly to the point of failure and could be weakened or damaged.
Nothing needs to be done to the other channel.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Understood thanks Perry.
| Rockford Fosgate Punch 200IX | seankane | Car Audio | 64 | 12th May 2011 12:48 AM |
| Rockford Fosgate Punch 400a4 | seankane | Car Audio | 62 | 14th April 2011 06:38 AM |
| rockford fosgate punch z | stevena2006 | Car Audio | 2 | 23rd December 2009 04:20 PM |
| Rockford Fosgate punch 200aIV | audiobahnkid592 | Car Audio | 2 | 27th October 2009 01:57 AM |
| rockford fosgate punch 200ix transformer plays music? | spooney | Car Audio | 2 | 15th October 2007 12:04 AM |
| Page generated in 0.06873 seconds (75.01% PHP - 24.99% MySQL) with 10 queries |
