Can't seem to find the RFG70N06 on octopart. Can those be replaced with something similar?
I have HUF75344G which appear to be similar in voltage, amperage, and total gate charge but then again I'm a novice at cross referencing. These are for the power supply in a Kicker ZR240. Thanks a lot.
Scope - DMM - 460W Computer PSU - Tutorial Last edited by m4ick; 2nd June 2011 at 10:11 PM. |
#2 |
The HUF75344G will be OK in that amp.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks, also the secondary ground trace to the crossover module is burned, is that module probably defective?
Scope - DMM - 460W Computer PSU - Tutorial |
#4 |
I doubt that burning the secondary ground would have affected the module but the modules have common failures so it may well be defective. If you're unsure and don't have a jumper/bypass module, jump the pins on the back of the vertical board and test it without a module.
#5 |
Awesome, I found the jumper diagram on your website, thanks a bunch.
Can a defective module blow an otherwise good amp or will it just cause issues?
#6 |
If you have the tutorial, the diagram is in the kicker folder.
Yes. I've seen modules that oscillated at a very high frequency which caused output transistors to overheat and fail. The problem was defective SMD capacitors in the module.
| help with replacement tweeter replacement - KLH twenty three | indianajo | Multi-Way | 2 | 15th February 2010 12:54 AM |
| Replacement 2sa1302 | Fredmullegun | Solid State | 3 | 7th August 2008 02:15 PM |
| Transistors replacement | funky2x | Solid State | 1 | 26th July 2008 12:20 AM |
| Replacement of a CDM1 | Rolly | Digital Source | 0 | 18th October 2004 08:12 AM |
| Page generated in 0.08082 seconds (75.07% PHP - 24.93% MySQL) with 10 queries |
