I got one of theese amps in for repair and i need to order some parts for this thing.
This amp was taken apart by someone else and alot is missing off the board. I missing the fets, outputs, power supply drivers, gate resistors, the rectifiers have broken legs, Class D board is fried, and ect.. So i need to order some parts but need help with a few of them.. Power supply fets are IRF3205'S Correct? Gate resistors are 100 ohms 1210 package?? Missing the power supply drivers : Q24 Q25 Q26 Q27 anybody know what part numbers they are?? Outputs are IXTQ36N30P correct?? And anyone find a good source for the rectifiers : MOSPEC F30D40D ?? |
#2 |
**** Yes Gate resistors are 100 ohms 1210 package?? **** Yes Missing the power supply drivers : Q24 Q25 Q26 Q27 anybody know what part numbers they are?? **** The originals are 2SD667s and 2SB647s but different transistors were recommended: kicker 1500.1 Outputs are IXTQ36N30P correct?? **** Yes And anyone find a good source for the rectifiers : MOSPEC F30D40D ?? ****No
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Ok going through this amp one more time and found that the blue crystal on the class D board has a broken leg..
Its marked 250MG Anyone have a good part number for that?? |
#4 |
Ok got parts in for this amp..
The orginal power supply drivers im replacing with MJE171 and MJE182G.. Will the MJE182G work as a good replacement for the MJE181 since i couldnt find anyone who had them.. Also is it the MJE171 or MJE182g middle pin connect to ground?? |
#5 |
The 171 will have it's middle leg connected to ground.
The 182G will work.
#6 |
Thanks.
Do you know what goes in board location Q22 ? |
#7 |
I can't tell on the photos of the 1500. If it's the same as the 1000, it's a TIP42C.
#8 |
#9 |
Do the drivers for the power supply fets face toward the power and ground terminals??
Do you know the value of C13 ? |
#10 |
Yes.
1uf@50v
| Kicker 1500.1 problem | Andrew123654 | Car Audio | 1 | 2nd November 2010 11:59 PM |
| Kicker ZX 1500.1 Spkr relay dropping early | Scanlines | Car Audio | 3 | 21st October 2010 10:18 AM |
| kicker 1500.1 | mike49504 | Car Audio | 66 | 14th July 2010 06:09 PM |
| Kicker ZX 1500.1 Smoked | general_neo | Car Audio | 10 | 26th July 2009 10:38 PM |
| Page generated in 0.08785 seconds (79.03% PHP - 20.97% MySQL) with 11 queries |
