Hello everyone I have a Rockford Fosgate 250m2 giving me a problem.
I recieved the amp with a blown power supply and shorted output fets. I removed all the output fets to eliminate problems upon powering up. I replaced all 6 p/s fets with new IRF3205 fets, replaced all 6 gate drivers with new 47 ohm resistors, and replaced 4 drivers transistors. The amp will not power up it draws full current on my power supply and makes a loud buzzing noise insided the amp and the p/s fets get hot. Since there is no output fets installed it cant be a shorted output. I was wondering maybe if it could be a shorted transformer?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#2 |
It could be a shorted transformer.
Have you checked the resistance across all of the solder pads for all of the missing and newly replaced transistors to see if there is possibly a solder bridge? If there are no bridges, remove the rectifiers to see if that reduces the current draw.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
There are no solder bridges, I will pull the rectifiers tonight to see if that reduces or eliminates the current draw.
If it does what would that determine???
| Rockford fosgate 4.6 X | mike49504 | Car Audio | 14 | 28th May 2011 03:35 PM |
| Rockford Fosgate BD1500.1 | mike49504 | Car Audio | 4 | 17th March 2011 10:39 PM |
| Rockford Fosgate T 15004 | mike49504 | Car Audio | 10 | 17th January 2011 03:23 PM |
| Rockford Fosgate | dtisme | Car Audio | 1 | 5th October 2010 11:39 PM |
| Rockford fosgate Bd1500.1 | mike49504 | Car Audio | 25 | 21st September 2010 05:24 PM |
| Page generated in 0.07200 seconds (71.07% PHP - 28.93% MySQL) with 10 queries |
