Go Back   Home > Forums > General Interest > Car Audio
Old 29th May 2011, 01:57 PM   #1
Mote is offline Mote  Estonia
Default Sound system in car does not play 100-200 Hz
We tried to improve my friends Subaru Legacy '04 sedans sound system by adding a closed box 10" subwoofer. Box is quite small 35 litres, element is made by quite unknown company - Sioux.
I burned 1000Hz to 20Hz sweep to cd, played it through subwoofer in house and recorded the result with microphone to computer. Played nicely down to 40Hz.
Now we installed box into the trunk of the car. Element is facing rear seat, armrest on the back seat is down, allowing the bass to go to interior of the car.
We placed microphone on the drivers seat headrest and played 1kHz to 20Hz sweep through cars audio system. Result was pretty bad, 200-100Hz did not show up at all on analyzer, other frequencies played at normal level.
Should we build another (inverted) box for element or replace cars original speakers? Any ideas at all?
Tools: C1-76 o-scope, Weller WHS40, Mastech MAS830L multimeter, Mastech MY6243 LC meter, 16A supply
Old 29th May 2011, 02:49 PM   #2
chris661's Avatar
Swap the wires to the subwoofers.
The subwoofer is cancelling the output from the other speakers.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
Old 29th May 2011, 03:14 PM   #3
How obvious
Will try that. Howcome I did not think of it?
Old 29th May 2011, 08:09 PM   #4
If reversing the polarity of the speakers doesn't help, turn off/disconnect all other speakers playing near 100Hz. If there is still a dip in the output, the problem may be in the vehicle.
I'm assuming that you're using the same signal source/amp. If not, are you sure that there isn't a crossover or equalization that's causing the problem?
Old 30th May 2011, 09:14 AM   #5
We can measure it again next weekend hopefully. He switched the subwoofer wires and said that bass got a bit louder. So I hope the problem is solved.
The car has factory head unit, 6 speaker sound system consisting of 2 tweeters, 4 4" speakers in doors and thats it. I doubt that these will play under 100 Hz.
Amps input signal is taken from rear door speaker because factory head unit does not have RCA output. We use a Rockford Fosgate amp and its Hi level input. We tried different settings on the amps filter section, full, LPF with different crossover frequencies but nothing helped.
Old 31st May 2011, 06:23 PM   #6
JRace is offline JRace  Canada
If you still get the `100-200Hz hole, then push the balance control all the way to one side (or the other, it don't matter).
Then if this gives you the bass you were missing, then swap the HI-Level input leads.
Old 1st June 2011, 06:00 AM   #7
amc32 is offline amc32  United States
If all else fails! Your problem may be an acoustical problem because of the orientation of the subwoofer. If the output of the subwoofer isn't coupled completely into the car, while the subwoofer are facing forward, very rarely will you achieve optimum performance without a null in freq. response. Try turning the subwoofer around or reposition in the corners of the trunk to allow the sub freqs. to load better
...............I Hear in color.................
Old 1st June 2011, 09:11 AM   #8
We changed the orientation of the subwoofer as well. Subwoofer facing backward with different distances from the backseat had some effect but the hole was still there.
Old 2nd June 2011, 12:12 AM   #9
ppia600 is offline ppia600  United States
Could just be equalization of the oem deck trying to make up for a bump in the car's peak resonances. Maybe try using the front speakers as the hi level source. Does his legacy have the oem amp/subwoofer box under the driver seat? You could use the output of that amp and just remove the woofer.
Don't worry... you can always turn the gain down!
Old 13th June 2011, 03:20 PM   #10
This Legacy does not have oem amp/subwoofer.
Anyway switching the wires did the trick. Friend is happy
Most musical basshorn 40 to 100 Hz rick57 Subwoofers 5 18th November 2005 01:08 AM
Most musical basshorn 40 to 100 Hz rick57 Multi-Way 7 16th November 2005 01:36 AM
Fullrange 100 hz and up Nate_Taufer Full Range 14 12th October 2005 03:15 AM
Bass box to 200 Hz – bother with CLD? rick57 Multi-Way 2 21st November 2004 10:35 PM
IGC 100 Hz buzz vmac011 Chip Amps 5 13th October 2004 06:20 AM
Page generated in 0.08814 seconds (82.00% PHP - 18.00% MySQL) with 10 queries
