Go Back   Home > Forums > General Interest > Car Audio
Old 29th May 2011, 03:21 AM   #1
seankane's Avatar
Default Rockford Fosgate Power 1100a2
Hello everyone.
I have a Power 1100a2 for repair. This amp was a mess. Complete power supply rebuild, all is well with that. One channel was completely fried. Rebuilt channel completely and everything is working great, amp sounds good and has clean signal on outputs.
My question?????
I remember Perry saying in a post that parallel outputs must match. So this means you could use 2 different brands in the same channel but the opposite channel has to have the same brand you put in the repaired channel?
Is this because of bridging? I used IRF640 by "IR" and the only IRF9640 I had were fairchild fets. Does this mean I have to put the same fairchild IRF9640's in the opposite channel?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 29th May 2011, 11:26 AM   #2
They don't have to match unless they're parallel. The ones in the two channels don't have to match each other.
Old 29th May 2011, 06:36 PM   #3
seankane's Avatar
So I used 5 IRF640 by "IR" and 5 IRF9640 by "fairchild" in the repaired channel. So the amp is clean and working great. I am ok to leave the other channel alone and everything should be fine?
Do I have to use fairchild IRF640's in the repaired channel to match the fairchild IRF9640's, or is everything ok how I have it?
Old 29th May 2011, 08:02 PM   #4
Leave the other channel as it is.
The 640s and the 9640s are not in parallel.
Old 30th May 2011, 01:38 PM   #5
seankane's Avatar
Gotcha now I understand, thanks Perry.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Rockford Fosgate Power 360a2 seankane Car Audio 219 26th April 2011 07:37 AM
Help Rockford 1100a2 stoke Car Audio 40 28th August 2010 06:49 PM
help with fosgate 1100a2 amp ben04srt Car Audio 31 23rd March 2009 07:56 PM
Rockfords fosgate 1100a2 output kelving Car Audio 1 12th November 2004 02:54 PM
Page generated in 0.07162 seconds (79.58% PHP - 20.42% MySQL) with 10 queries
