Go Back   Home > Forums > General Interest > Car Audio
Old 13th August 2003, 09:47 PM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Default A question
Is my idea totally wrong or is there something right?
Thanx in advance!
Old 14th August 2003, 05:45 AM   #2
tsmith1315's Avatar
Things to ponder...
What's R12's purpose? Its commonplace to tie the secondary CT to ground.
Given the output is significantly higher than what you were expecting, it sounds like the turns ratio is off a bit.
If the output isn't symmetrical with respect to the CT, are you sure it's really in the center? If so, it sounds like you don't have a good square waveform. I suppose a crippled rectifier could also cause asymmetricality, but certainly it would overheat to cause that much difference. Are the diodes fast enough to work at your switching frequency?
I don't know much about PWM controllers, but that looks like a heavy load for it to drive directly. Is the SG3524 capable of that much current?
Have you tried the circuit without regulation?
The big question: do you have a 'scope to snoop around with?
Tim
Old 14th August 2003, 06:03 AM   #3
MaXiZ's Avatar
Default Precisation
Sorry now there's the right image!
Old 14th August 2003, 06:05 AM   #4
MaXiZ's Avatar
What mean r12,s?? And CT?
I'm a beginner sorry!
Old 14th August 2003, 05:24 PM   #5
MaXiZ's Avatar
Default the diodes
And as diodes i've used 4 BYW29-50.
And these are the image on how i've wind the transformner... A tronsformer recovered from a burned PC Power Supply of 300W!
ANd i've tested that from pin 11 and 14 i've exactly the same voltage.. 10.1V AC
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
