Go Back   Home > Forums > General Interest > Car Audio
Old 26th May 2011, 07:50 AM   #1
Default Rockford fosgate 400S
I replaced the power supply fets and the rail caps in this amp.
I get 9 volts on the left channel outputs so i replaced all outputs in that channel And still have 9 volts on output terminals..
Any ideas??
Old 26th May 2011, 10:15 AM   #2
kds9591 is offline kds9591  United States
Default Driver Transistors.
Check your driver transistors to see if they are shorted. I believe they may be numbered Q2-Q5 near the center of the board. They are SMD transistors marked 1A,2A on case.
Old 26th May 2011, 11:25 AM   #3
If you don't find any open gate resistors, open driver resistors or leaking/shorted/open driver transistors...
If you touch a speaker or dummy load to the speaker terminals, does the DC drop to 0v?
If you allow the amp to remain on for 5 seconds (no load) does the DC drop to 0v?
Old 26th May 2011, 05:28 PM   #4
All gate resistors measure 10 ohms I replaced the driver transistors and checked the driver resistors all seem fine..
Amp still has 9 volts of DC on outputs.
If i connect a speaker to that channel voltage remains at 9 volts and amp draws excessive current.
If i leave the amp on for 5 secs or longer the voltage remains it never drops
Old 26th May 2011, 09:18 PM   #5
Lift Q109 and Q111. Does that get rid of the DC offset?
Old 26th May 2011, 11:53 PM   #6
Yes it went away Q106 was defective.. Do you know what part that is??
Old 27th May 2011, 09:43 AM   #7
Q106 is an MMBT3906 but that wouldn't cause it to have DC offset. That's a protection circuit component.
Old 27th May 2011, 06:19 PM   #8
So what should i check for?? Q106 and Q111 are still removed.
Old 27th May 2011, 06:38 PM   #9
Do you mean Q109 and Q111?
Old 27th May 2011, 06:56 PM   #10
Yes Sorry
Rockford fosgate 4.6 X mike49504 Car Audio 14 28th May 2011 03:35 PM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate 600.5 mike49504 Car Audio 68 20th March 2010 05:32 PM
Need help with Rockford Fosgate 801s robsmetalcraft Solid State 3 27th February 2010 09:28 PM
Rockford Fosgate 801s mike49504 Car Audio 11 17th February 2010 11:47 PM
Page generated in 0.10325 seconds (78.04% PHP - 21.96% MySQL) with 10 queries
