Go Back   Home > Forums > General Interest > Car Audio
Old 26th May 2011, 02:18 AM   #1
Default Rockford fosgate 4.6 X
i replaced the outputs and emitter resistor in the right rear channel.
when i power it up and test for output the left rear channel has no output and the right rear channel has very low distorted output. I tryed cleaning the gain pots and swapped the crossover cards still no change..
Any ideas?
Old 26th May 2011, 04:12 AM   #2
seankane's Avatar
Wondering if this is the same board as the 4600X? Can you post a pic of the board? Do you have good supply voltage on all of the op-amps pins 4 and 8? Have you checked for an open or out of tolerance SMD resistor? Have you checked to see if the rail caps are leaking? Have you checked to see if the RCA connections are loose or came un-crimped? Have you checked for loose or cold solder joints on the cross-over card slots?
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 26th May 2011, 06:42 AM   #3
Drive a signal into the LF and RR channels. Compare the signal levels on pin 1 of U102 and pin 7 of U302. Are they they same?
Set all crossovers and gains the same.
Old 26th May 2011, 07:56 AM   #4
Yes they are the same they match perfectly
Old 26th May 2011, 11:27 AM   #5
What's the DC voltage on the emitter of Q105 and Q405?
No input signal.
Old 26th May 2011, 04:50 PM   #6
Q105:-9.58
Q405:-9.60
Old 26th May 2011, 09:19 PM   #7
Did you touch the scope probe to the output transistors of the dead channels to confirm that there is no audio on any of the outputs?
Old 26th May 2011, 11:58 PM   #8
I placed probe on output transistors and the sine wave is flat on the top side it looks like a square wave
Old 27th May 2011, 09:44 AM   #9
Which leg of which transistor looked like that?
Can you post a photo of the distorted waveform?
Old 27th May 2011, 06:50 PM   #10
Scope set to .5 volts/div and 2 ms. and 100hz sine wave
First pic is the middle pin on the 9540 and 2nd pic is middle pin on 540 both rear channels have the same wave on the outputs
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 03:20 AM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Need help with Rockford Fosgate 801s robsmetalcraft Solid State 3 27th February 2010 09:28 PM
Rockford Fosgate 801s mike49504 Car Audio 11 17th February 2010 11:47 PM
rockford fosgate // alpine mike49504 Car Audio 1 25th December 2006 09:36 AM
Page generated in 0.09763 seconds (77.14% PHP - 22.86% MySQL) with 11 queries
