Rockford fosgate 4.6 X
Old 27th May 2011, 07:25 PM   #11
Perry Babin is offline Perry Babin  United States
The 540 and 9540 should have the same waveform. They're directly connected so you don't need to post photos for each one.
Connect a load and post a photo of the waveform again.
Confirm that you're at 0.5v/div and not 5v/div by touching the probe to 12v. If you're at 0.5, the trace should deflect off of the display.
Old 27th May 2011, 07:48 PM   #12
mike49504 is offline mike49504  United States
Ok for some reason now the Right rear channel works perfectly.
Left rear channel has output but very distorted..
Old 27th May 2011, 07:55 PM   #13
Post a photo of the distorted signal with a load.
Have you confirmed that the problem isn't due to dirty pot/switch contacts?
Old 27th May 2011, 08:15 PM   #14
Yes i cleaned the pot and worked it back and fourth 100 times. There are no switches on this amp. I also replaced the crossover card.
Scpoe is set at 0.5 volts div 1ms and a 100 hz sine wave
Old 28th May 2011, 03:35 PM   #15
Ok amp is fixed found 2 bad resistors and a defective MMBT3906
Rockford fosgate 4.6 XHide this!Advertise here!
Rockford Fosgate P75.2 chipper Car Audio 9 3rd January 2011 03:20 AM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Need help with Rockford Fosgate 801s robsmetalcraft Solid State 3 27th February 2010 09:28 PM
Rockford Fosgate 801s mike49504 Car Audio 11 17th February 2010 11:47 PM
rockford fosgate // alpine mike49504 Car Audio 1 25th December 2006 09:36 AM
Copyright ©1999-2017 diyAudio
