Go Back   Home > Forums > General Interest > Car Audio
Old 25th May 2011, 09:37 PM   #1
Default connect mp3 to the stereo directly throught the CD changer in back
I want to connect an mp3 connection to the car stereo through the CD changer/auxiliary port in the back without having to buy the 50$ adapter. Can I just splice into the head phone wires and wire them into the cd changer port somehow so the signal will be recieved by the stereo? Thanks much.
Old 26th May 2011, 12:02 AM   #2
Banned
Have you looked at the back of the head unit? You say auxiliary port. If it has an aux. input selectable from the front panel, you can wire in there from a headphone out.
w
Old 26th May 2011, 03:34 PM   #3
Thanks for the reply. The auxilliary port in the back of the factory radio is for a cd changer or other auxilliary device. Its on a 2003 honda odyssey. I've checked the pins for voltage and two are 12, one is like 4 and one is 1.5 volts. The rest do not give off volts so I can't tell what they do. Trying to find a pin diagram on the net but so far unsuccessful. I don't need to power my mp3 (although it would be nice) just send its signal through that cd changer/aux port in the back. It has like 12 pins if I remember right.
Old 26th May 2011, 04:04 PM   #4
amc32 is offline amc32  United States
Who is the manufacture of the OEM radio you are trying to use?
...............I Hear in color.................
Old 26th May 2011, 04:06 PM   #5
Please look on the radio itself, because it isn't Honda.
Old 27th May 2011, 09:42 PM   #6
I have checked and yes it is a factory stock radio (we are the original owners and never had a different radio put in) and it says honda on the front top
Old 27th May 2011, 09:46 PM   #7
Here is a picture of the front of the radio.
Old 28th May 2011, 12:59 AM   #8
Banned
What I want to know is: can you get 'AUX' to come up on the display by pushing the buttons on the front.
If you can, it's just a matter of finding out which are the AUX input pins, which can be done by powering up the radio (with speakers attached) and applying an audio signal to the pins in turn. Obviously you want to avoid the ones with power on them, but you could, for example, take a portable player, plug into the headphone out with an old cable from a pair of bust or disused headphones (most people have a disused cheap pair) and connect a capacitor to the common wire and to one of the signal wires. Pretty much any caps will do for the test, but fairly big ones but non-electrolytic are best. Now you can probe the pins with the 2 free leads on the caps without risk of damaging the player.
The sound may not be good with the caps in series but once you've found the pins you can connect without them. Using the caps may be overkill since the player probably has caps already on its output, but better safe than sorry.
If you can't get 'AUX' to come up on the display, it MIGHT work on the 'CD' setting, otherwise it's a bust.
w
Old 28th May 2011, 02:03 AM   #9
ppia600 is offline ppia600  United States
may be an oem alpine
Don't worry... you can always turn the gain down!
Old 31st May 2011, 07:05 PM   #10
no way to activate aux by pushing a button on the front panel. I read some posts elsewhere that said the cd changer sends a signal to tell the radio activate aux display.
Onkyo DX C390 6-CD changer - First CD DIY project Lord Le Brand Digital Source 2 17th April 2011 01:52 PM
DIY CD Player with RC, display, 2 drives changer and CD-Text. dxer_87 Digital Source 12 26th November 2010 02:06 PM
Can i connect directly DIR1701 DIN to cd-rom,Sb live s/pdif output azyx Digital Source 2 28th March 2004 01:04 AM
Cool MP3 cd changer substitute Variac Car Audio 3 13th October 2003 05:20 PM
Active cross-over, solid state amps connect directly to tweeter? Drew Eckhardt Multi-Way 14 24th August 2003 06:36 AM
Page generated in 0.09412 seconds (80.03% PHP - 19.97% MySQL) with 11 queries
