Go Back   Home > Forums > General Interest > Car Audio
Old 23rd May 2011, 11:17 AM   #1
Default can't find output transistors data...
i'm working on an os targa q-58mx and upgrading the irfz42's to irf3205's, and i was just checking on the outputs, but could not get a reference to them. they seem to be fine, but just in case, i was curious. they have a big k on top, and the numbers are b688, and d718. anyone know what they cross to? would tip35c/36c be a good replacement, if needed?
Old 23rd May 2011, 11:25 AM   #2
Banned
Just put 2S in front of the number:
2SB688 and 2SD718
Old 23rd May 2011, 12:57 PM   #3
In general, the TIP35C and TIP36C are not a good sub because they require different biasing.
The FJA4313 and FJA4213 are good subs (well, they have been in all the amps I've used them in).
If it has a K for the logo, they're made by KEC. KEC uses a KT prefix but transistors that use the 2S prefix are generally the same part.
focal data sheet - where to find? cynamon Multi-Way 3 20th November 2009 05:23 PM
Can't find data for 8624 ladeklof Tubes / Valves 3 29th February 2008 08:38 PM
Where to find data sheets? Zap Tubes / Valves 4 20th November 2007 06:38 PM
LF358, would like to find data sheet and/or replacement, thanks pat allen Parts 3 7th January 2005 07:22 PM
Power Transistor data Sheets... where to find Harlan Parts 3 21st February 2004 03:03 PM
Page generated in 0.06182 seconds (70.09% PHP - 29.91% MySQL) with 11 queries
