Soundstream 204 40W/Chan power amp. It won't power up. Voltage drops to 6V when the fuse is installed. I don't have the schematic. Power chip is SG3524N. NPN Power FETs are BUZ11. Rectifiers around the transformer are FEN16CT. The OP amps are TL074CN quad JFET. Output FETs are TIP102 and 107s. I'm new to electronics repair and I don't know where to start on this. Nothing looks burnt. One resistor looked discolored but had the right resistance when I removed it. I tried to follow a dead amp tutorial but couldn't get past this point.
#2 |
What are you using for a power supply?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Thanks for the reply. I should have mentioned this in my first post. When hooked up to a 12V battery, the amp would blow the 20A fuse so I thought if I used a much weaker supply, I might be able to see what is going on. I'm using a 5A Class 2 switching power supply. It plugs into the 110AC and outputs 13VDC.
#4 |
Update: I looked at your basic amp guide and followed it to find at least part of the problem. All of the 8 output FETs are bad in one way or another. Some are shorted and some leak current back. Once they have been removed from the amp, the power side seems fine. The center pin on the BUZ11s on the power side reads 12.39V and the 4 rectifiers near the transformer read 21.45V. It looks as though someone has already replaced some of the output FETs in the past. Before I replace all of them and power it back up, is there anything else I should check in case there is another fault that is causing them to fail?
#5 |
The outputs in this amp are not FETs. They're darlington bipolar transistors.
You should confirm that all of the emitter resistors are within tolerance (likely 0.1 ohms, ±5%). If at least one TIP102 and one TIP107 is good. Reinstall them (all that are not defective), clamp them tightly to the heatsink and power it up to see if it will produce audio.
#6 |
Thanks for that clarification. The resistors all read 0.1 Ohms but I can't see finer tolerance since my meter only reads to tenth Ohms. None of the TIP102 are good. I was able to buy a replacement TIP107, but without the TIP102, I can't try it out. I'll just order all of them and try out a single pair to see if I get audio. Would substituting TIP142T/147T for TIP102/107 be OK? I thought the higher current capacity might make them less likely to fail in the future. Any suggestions for improvements to any of the components would be welcome.
#7 | |
Wiping off the old dry heatsink thermo compound and using new will provide better heat transfer improving reliability. Keep us posted on your repair progress.
| Q about connecting transformer 6v-0-6v | Hubba | Power Supplies | 5 | 10th November 2010 09:12 AM |
| $50,000 power amp !! Anyone know what's inside it ?? | Trevor White | Solid State | 22 | 6th March 2010 10:16 AM |
| Converting Bogen chb-35a to more guitar friendly amp (newbie inside) | thehoj | Tubes / Valves | 8 | 23rd August 2009 07:13 PM |
| How to power a led inside an amp | AndersJ | Chip Amps | 18 | 16th April 2006 03:58 AM |
| Using 6V to power 12V DAC | Ian J | Digital Source | 0 | 4th January 2004 06:18 PM |
| Page generated in 0.07947 seconds (83.11% PHP - 16.89% MySQL) with 10 queries |
