Go Back   Home > Forums > General Interest > Car Audio
Old 15th May 2011, 07:20 PM   #1
Default autotek model 44 repair help
Alright I have a autotek model 44 previously had issues with powering into protect mode. Replaced n4751 @zd1 next to ohm load switch. Switch selects between 1 and 2 ohms. Amp powers up now with input level turned down to lowest level if you turn of all the way up it goes to protect with no speakers or RCA cables connected. Connected RCA cables and a 3 ohm speaker up to channel 1with audio playing. No sound at all but speakers does full excursion in then out then rests. Does repeatedly. Does this on both channels. When speaker is bridged does nothing.
Tested all output fets all test fine.
Old 15th May 2011, 09:43 PM   #2
timwebb is offline timwebb  United States
u check the output driver transistors?
Old 15th May 2011, 09:47 PM   #3
if your talking about the output fets.transistors, yes i did. If not, please inform me of what they look like.
thanks
Old 15th May 2011, 10:33 PM   #4
Can you post a photo of the board so I can see precisely which amp this is?
Old 15th May 2011, 10:52 PM   #5
as you can see the board got kind of "crispy" where the diode i guess it is blew. previous owner said he ran it below 1 ohm maybe even with switch in 2 ohm position. the amp is an autotek 44 revision d.
Old 15th May 2011, 10:57 PM   #6
What's the resistance between the RCA shields and the non-bridging speaker terminals?
If you place the black probe on one of the non-bridging speaker terminals, what is the DC voltage on pins 4 and 11 of the 14-pin op-amps?
With no speakers connected, what's the DC voltage measured directly across the speaker terminals for each channel? Place the black probe on the non-bridging speaker terminal when reading the voltage on both channels.
Old 15th May 2011, 11:23 PM   #7
alright, resistance between rca shields and non bridging terminals is .4 on both terminals and both shields, which is the resistance of my probes touching, so 0 ohms.
secondly, i assumed when you said 14 pin op-amps, you meant the 3 14-pin ic chips.
if so then here are the measurements. as labeled on board.
ic-101
pin 4(19.55)
pin 11(11.67)
ic-201
pin4(19.63)
pin11(11.26)
ic-3
pin4(11.45)
pin11(11.09)
lastly w/no speakers connected the dc voltage measured directly across speaker terminals on each channel was
ch.1(.17)
ch.2(.15) fluctuating to (-.20)
If i a wrong about the op amps, please let me know what they look like. thanks
Old 16th May 2011, 03:29 AM   #8
What were you using for a signal source when the speaker was pulsing in and out?
Old 16th May 2011, 03:56 AM   #9
Car radio. RCA s and radio work fine on another amp
Old 16th May 2011, 05:17 AM   #10
Are the RCA shields on the head unit OK (0 ohms to the case of the head unit)?
Is the head unit ground connected to the amp ground?
autotek mean machine amx 100.2 repair grandam88 Car Audio 11 21st January 2011 04:47 PM
looking fot autotek mean machine 44 schematics grandam88 Car Audio 7 18th January 2011 06:04 PM
Forte Model 44 neekos Solid State 0 13th November 2010 09:55 PM
autotek 44 aka 7100bts problem with left channel eroc1313 Car Audio 15 18th March 2010 12:07 AM
Old school Autotek repair question w/pic beco Car Audio 4 9th August 2008 09:37 AM
Page generated in 0.09829 seconds (77.57% PHP - 22.43% MySQL) with 10 queries
