Go Back   Home > Forums > General Interest > Car Audio
Old 14th May 2011, 01:41 AM   #1
seankane's Avatar
Default Rockford Fosgate BD500
Hello everyone.
I have a problem with this Rockford BD500.
The amp is stuck in protect. I have did a few checks and this is what I found.
There is no dc on speaker terminal.
The amp is producing rail voltage of 71.4 vdc on the red and black wires.
All op-amps have supply voltage.
Pin 1 of U11 has a nice square wave form.
Pin 7 of U11 has a nice triangle wave form.
Q16 reads as follows: Q15 and Q16 are getting very hot.
leg 1: -8.53 vdc
leg 2: -17.98 vdc
leg 3: -9.78 vdc
U21 reads as follows:
pin 1: -8.53 vdc
pin 2: 7.90 vdc
pin 3: -8.98 vdc
pin 4: -9.78 vdc
pin 5: 4.99 vdc
pin 6: -7.55 vdc
pin 7: 8.45 vdc
pin 8: 9.80 vdc
All output fets have between +9.76 and +9.66 vdc on the gate legs.
Q111: 0.000 vdc drain
Q112: 0.000 vdc drain
Q104: -75.5 vdc drain
Q105: -75.5 vdc drain
Q108: 0.000 vdc drain
Q109: 0.000 vdc drain
Q101: -76.0 vdc drain
Q102: -76.0 vdc drain
Q101: last leg to + speaker terminal is: -0.002 ohms
Power supply fets have 7.82 vdc on all the gate legs but viewing the gate signal with the scope of the p/s fets it looks kinda funny. Very big squares deflecting only upward about 4 divisions.
Any help would be greatly appreciated. Thanks very much.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 14th May 2011, 02:39 AM   #2
seankane's Avatar
I suspected U21 and changed it out with a new one and the amp works great.
Old 14th May 2011, 10:31 PM   #3
If the DC voltage on pin 6 is every below 0v, there is no doubt. The IC has failed.
Rockford Fosgate BD1000 mike49504 Car Audio 1 9th January 2011 11:37 AM
Rockford Fosgate dtisme Car Audio 1 5th October 2010 11:39 PM
Rockford Fosgate BD500 mike49504 Car Audio 9 18th July 2010 07:43 AM
Rockford Fosgate 800.2 Brain Fried Car Audio 2 16th April 2010 05:14 PM
rockford fosgate // alpine mike49504 Car Audio 1 25th December 2006 09:36 AM
Page generated in 0.07365 seconds (71.96% PHP - 28.04% MySQL) with 10 queries
