ok i got this amp the neg side of the out put keeps shorting out. i checked the resistors they are good
#2 |
Can you post a photo showing a larger area of the board?
Do you mean that the output transistors connected to the negative rail fail repeatedly?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
yes.they keep failing.
#4 |
That looks like a version of the massive/SinusLive amps.
Remove all of the outputs and short the positive and negative speaker terminals together. What is the DC voltage for the high and low side FETs when you place the black probe on leg 3 and the red probe on leg 1?
#5 |
5volts
#6 |
That's about what I'd expect.
Are all of the gate resistors within tolerance? Are there any traces that could open intermittently? Does the same FET on the low side blow every time or do they fail randomly? Do ALL of the low side FETs fail (checked out of the board) EVERY time they fail?
#7 |
Are all of the gate resistors within tolerance? yes.
Are there any traces that could open intermittently? no Does the same FET on the low side blow every time or do they fail randomly? theyblow everytime. Do ALL of the low side FETs fail (checked out of the board) EVERY time they fail? yes. |
#8 |
It's odd that ALL 4 of the FETs fail at once. This would tend to indicate that the drive voltage is spiking.
Is the center leg of these 4 FETs directly connected (~0 ohms) to the output filter inductor?
#9 |
no im getting a very high ohm reading
#10 |
Check the other 4 FETs (center leg to inductor).
| Diamond Audio D6 1500.1 diagram | clayton | Car Audio | 10 | 14th May 2012 01:46 PM |
| Tuning my pipe | mikee55 | Multi-Way | 3 | 24th April 2007 08:14 AM |
| Diamond Audio D6 1500.1 manual? | mbayaq579 | Car Audio | 2 | 8th March 2007 07:30 AM |
| El-Pipe-O (El-Pipe-Mino) ??? | JDeV | Multi-Way | 21 | 26th October 2005 09:00 AM |
| El Pipe-O | Nelson Pass | Multi-Way | 7 | 9th January 2003 06:30 AM |
| Page generated in 0.09108 seconds (76.76% PHP - 23.24% MySQL) with 11 queries |
