I am working on a punch 200 amp (25/4-4ohms)This amp will not power up.I replace 4 burnt ps fet (irfz44) D3 (1N4003 shorted)It also had two shorted sm transistor (p2gb)I install two a733 in there just for test.I have 14.2v on all the center leg of the ps fets.On the first leg i have 1.5v and the third has .0v.I used a 1n4001 in place of the 1n4003
LM339D pin 1: .1vdc pin 2: 6.3v pin 3: 14.5v pin 4: .2v pin 5: 2.5v pin 6: .0v pin 7: 14.5 pin 8: 4.7v pin 9: 4.8v pin10: 4.8v pin11: 8.9v pin12: .ov pin13: 6.3v pin14: 6.3v TL494 ic pin 1: .0vdc pin 2: 4.5v pin 3: .0v pin 4: .1v pin 5: 1.5 pin 6: 3.3v pin 7: .ov pin 8: 14.1v pin 9: 3.4v pin10: 3.4v pin11: 14.1v pin12: 14.1v pin13: 4.8v pin14: 4.8v pin15: 4.8v pin16: .0v any idea what could be the problem? |
#2 |
Are the gate resistors within tolerance?
Did you check the NPN driver transistors to confirm that they were not open/damaged? Do you have a scope?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
The NPN transistor had a good reading on board.some of the gate resistors is install upside down.Am guessing all of them should be the same at 1o ohms?I dont have a scope.
#4 |
What's the PC-# on the circuit board?
#5 |
pc 3084
#6 |
I don't have the schematic diagram for that amp but the 800.4 (PC-3085) used 10 ohm gate resistors so it's possible that that's what this amp should have.
What's the DC voltage on the base, collector and emitter of the NPN driver transistors?
#7 |
i found two bad gate resistors but still no change
npn sm transistor 1 base 5.6v collector 14.5v emitter 1.8 transistor 2 base 5.6v collector 14.4v emitter 1.7v |
#8 |
Those appear to be defective also. With 5.6v on the base, I'd expect something closer to 5v on the emitter.
#9 |
Perry I have a board sitting here that is a 500x 4 channel like the one you helped me with and it is a PC 3084. Irfz44 never came in these stock. They used irf3205 and I have seen them with MTP50N06V. Not saying they wont work just never seen those in one of those amps.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch |
#10 |
I would consider starting over and rebuilding the power supply. I would install 4 new p/s fets, 4 new gate drivers, and 4 new driver transistors.
I would also check the transformer for broken legs as the one I just repaired had 2 broken legs. Chances are if you have defective gate drivers you have p/s fets that are defective as well. Make sure you dont have any shorted output fets or when you do get this amp up and running you could have another p/s failure.
Pyramid 46 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch Last edited by seankane; 11th May 2011 at 08:19 PM. |
| bias current on rockford punch 200.4 | Ground Zero | Car Audio | 2 | 5th April 2010 05:06 PM |
| odd punch 200.2 issue | spooney | Car Audio | 16 | 17th October 2009 02:46 AM |
| Punch 200.4 PS problem? | RJCRAFTS | Car Audio | 5 | 25th June 2008 01:21 AM |
| Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY | ppia600 | Swap Meet | 0 | 23rd February 2008 01:17 AM |
| My experience: the cheap punch set VS Greenlee punch | vax9000 | Tubes / Valves | 5 | 21st July 2006 07:52 PM |
| Page generated in 0.10130 seconds (87.24% PHP - 12.76% MySQL) with 10 queries |
