Can anyone tell me what type of enclosure I should use for an Audiobahn Alum12N? It has the following T/S parameters:
Fs 24.4 Hz Qts 0.56 Qes 0.51 Qms 4.9 Vas (Cu. Ft.)2.66 Cu.Ft Re 5.4 ohms Le 2.7 mH Mmd 186 Grams Xmax +/-14 mm RMS 1000 Watts Sd 0.049 M2 Freq. Resp. 18Hz-500Hz Efficiency 96.4 dB Ideally I'd like to use a ported box, tuned to around 38hz, 1.5 cf per chamber, but have no idea how the driver would respond in it. Any suggestions? |
#2 | |
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Would I gain anything using a ported enclosure, around the same volume (~1.5cf), ported to say 38hz?
Or would this adversely affect sound quality? |
#4 |
It will boom. You might like this. A 4" flared port ~13" long should be considered minimum. If you don't like it, stuff a sock in the port...
#5 |
I downloaded WinISD and entered the speaker parameters in. (Qts should have been 0.47 btw, all other parameters are correct).
It shows a 1.4cf sealed box to have an F3 of 37.14hz, the rest of it is fairly linear, where it flattens around 62 hz at 0db gain. The ported box at 1.45cf tuned to 38hz peaks around 50hz at +4.9db. Is this the "boom" you describe, meaning it is very loud over a narrow frequency range? How "boomy" would this be? Gain falls off to 0db around 37.5hz, and F3 is near 33.5hz. Recipe for disaster, or does it look like this ported enclosure may have decent sound quality? Sorry for the beginner questions! I suppose if I don't like it, I could just close off the port to make it sealed... |
#6 |
that would be in an open area without any echo. When you put it in the car, cabin gain comes into play and the lows get boosted.
| What type of enclosure?? | e-side | Multi-Way | 5 | 25th December 2005 06:17 PM |
| what type of enclosure is bazooka? | fossilfool | Subwoofers | 8 | 28th November 2005 04:43 PM |
| loudest enclosure type? | MEXXX | Multi-Way | 17 | 20th October 2004 12:05 PM |
| Page generated in 0.07565 seconds (75.71% PHP - 24.29% MySQL) with 10 queries |
