i replaced u404 and 403, many times because im getting -16volts on pin 7 on both opamp, at last i measured the ping 6 on u404 after pull out the opamp and some resistor when i was looking for the source of the neg. voltage
this is what im gettin right now.. i pull out r406, u404 and u403 check this pic
#2 |
Can you send me a copy of the diagram. I can't read the text.
babin_perry@yahoo.com What is the DC voltage on pin 5?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
remember u404, u403 and rb406 are pulled out check your email |
#4 |
If you set your meter to diode check and place the red probe on pad 6 or 7 for U404 (black probe on amp ground), what does your meter read?
Are any of the pins in the remote bass level jack crossed?
#5 |
both pin read open.... i removed r72 to see if the problem came from the remote bass jack, but not with r72 pulled out the neg volt was on pin 6 and 7 u404
#6 |
Is there any DC on the speaker terminals?
Does the position of the crossover switch make a difference?
#7 |
no there is no any dc on speakers terminals and the switch dosen't make any diff
#8 |
Is there any DC voltage on the frame of the crossover switch?
#9 |
#10 |
Do you have -10v on any pads (not the power supply pads) for U402 or U403?
What's the DC voltage on the RCA shields?
| Rockford Fosgate bd 1000.1 Problem | lukeman269 | Car Audio | 11 | 8th April 2011 10:35 PM |
| Help with rockford 851s | stoke | Car Audio | 34 | 8th February 2011 05:03 PM |
| Rockford 800a2 problem with right channel | Witwe | Car Audio | 17 | 17th December 2010 03:50 PM |
| Rockford Fosgate POWER 250x2 problem | chemhaz | Car Audio | 2 | 15th August 2010 09:08 PM |
| rockford 4060x problem.. | marko | Car Audio | 5 | 17th March 2009 06:52 PM |
| Page generated in 0.09012 seconds (81.55% PHP - 18.45% MySQL) with 10 queries |
