Rockford Fosgate Punch 200IX
Old 9th May 2011, 08:59 AM   #21
seankane is offline seankane  United States
seankane's Avatar
What am I looking for after I lift Q226 and Q230?
Old 9th May 2011, 07:55 PM   #22
seankane's Avatar
Should I be lifting Q126 and Q130 to see if it gets rid of the DC on the 100 series channel?
Pyramid 52 Amp Power Supply----Fluke 787 Processmeter----Tektronix 465 Scope----Velleman HPS40 Scope----Soldering Iron----Desoldering Iron----Hejet HJ 500-S Heatgun----DM4070 Digital LCR Meter----Propane Torch
Old 10th May 2011, 12:01 AM   #23
Perry Babin is offline Perry Babin  United States
Those should disable the protection circuit. Does the amp draw excessive current?
Old 10th May 2011, 01:16 AM   #24
seankane's Avatar
Lifted Q226 and Q230 and the amp actually draws less current now.
Shall I remove Q126 and Q130 as well or wait?
Old 10th May 2011, 04:15 AM   #25
Does that channel produce audio with those transistors out of the circuit?
If you have other transistors out of the circuit, reinstall them but leave 226 and 230 out for now.
Old 10th May 2011, 04:22 AM   #26
seankane's Avatar
Yes it does produce audio.
Old 10th May 2011, 04:27 AM   #27
Clean audio?
Old 10th May 2011, 04:30 AM   #28
seankane's Avatar
Yes it seems to be clean, but sounds kind of crackly when you get over 5/8 volume on the head unit. The bias is not set for this channel either.
Old 10th May 2011, 04:41 AM   #29
Is either of the transistors that are out of the circuit leaking or shorted?
Old 10th May 2011, 04:48 AM   #30
seankane's Avatar
Well they both seem to be leaking. From collector to base I get 15.45 M ohms on both of them.
I checked a new one and it reads OL from collector to base.
This was out of the circuit testing of course.
Rockford Fosgate Punch 200IXHide this!Advertise here!
Rockford Fosgate Punch 400a4 seankane Car Audio 62 14th April 2011 07:38 AM
Rockford Fosgate Punch 325.1 Mote Car Audio 5 28th September 2010 01:51 AM
rockford fosgate punch z stevena2006 Car Audio 2 23rd December 2009 05:20 PM
Rockford Fosgate punch 200aIV audiobahnkid592 Car Audio 2 27th October 2009 02:57 AM
rockford fosgate punch 200ix transformer plays music? spooney Car Audio 2 15th October 2007 01:04 AM
