Amp powers up and idle's perfectly. Amp is producing both + - regulated voltages And also is producing both + - 82 volts of rail voltage
Amp has no output Wondering where i start? I noticed the amp has a D1303 transistors Near the output driverboard Is that what they are using for the muting transistor? |
#2 |
Post a photo of the board.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
heres some pics of the board i know all the fets arent in right now i gotta clean up the board . i only have a few in for testing
#4 |
Are all of the outputs in it?
Are both power supplies producing output (square wave on the outer legs of the secondary windings? Is the relay engaging?
#5 |
The file name for the photos indicates that they are for a hifonics amp. Is this the amp you're working on or is it a similar amp (subject says MB Quart).
#6 |
Its a MB Quat amp Sorry forgot to change the photo name
#7 |
ALL of the outputs are in the amp.
Relays are kicking on. I see a square wave on the secondary windings |
#8 |
Do you see any rail-rail oscillation on the outputs?
#9 |
The trace deflects thats all it does
#10 |
Is this audio driver board the one with two 14 pin driver ICs?
| MB Quart tweeters | Coenlaf | Multi-Way | 25 | 18th January 2011 04:36 AM |
| MB Quart RAA1000 | mike49504 | Car Audio | 1 | 1st January 2010 02:28 AM |
| Help with MB Quart Speakers | stax | Multi-Way | 4 | 30th November 2007 02:21 PM |
| FS: Scan-Speak 25W/8562 woofers/MB Quart MBM 50 S Mid-Range/MB Quart MCD 19E Tweeters | Ballylongford | Swap Meet | 0 | 1st August 2006 06:20 AM |
| MB Quart | Slinkylink | Multi-Way | 1 | 14th September 2005 12:56 AM |
| Page generated in 0.08358 seconds (79.26% PHP - 20.74% MySQL) with 11 queries |
