Go Back   Home > Forums > General Interest > Car Audio
Old 4th May 2011, 11:04 PM   #1
stoke is offline stoke  ominican Republic
stoke's Avatar
Default help rockford bd15001
hi, i got this amp this morning and when i power up i got 20volts on the speaker terminal and when i plug the remote out the amp looks like is still on but the protection led turns on. its only turn off after remove the battery cable. i checked all output transistor and all look fine.
Old 4th May 2011, 11:08 PM   #2
Do you have positive or negative 20v on the positive speaker terminal?
What is the DC voltage on all pins of U17?
What is the DC voltage measured directly across the red and black twisted wires?
Old 5th May 2011, 12:51 AM   #3
stoke's Avatar
there is 28.5v positive speaker terminal
u17
1;0
2;8.3
3;0
4;-9.7
5;0
6;1.1
7;9.8
8;0
there is 71volt across the red and black twisted wires
Old 5th May 2011, 01:12 AM   #4
That op-amp appears to be defective.
Old 5th May 2011, 04:33 AM   #5
stoke's Avatar
u17 replaced, now when i turn on, there isn't any voltage on speaker terminal but the amp gets on protected mode and stay on after remove the remote cable
Old 5th May 2011, 04:45 AM   #6
Post the DC voltage on U21.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 5th May 2011, 05:08 AM   #7
stoke's Avatar
Pin 1: 8.2
Pin 2: 0
Pin 3: 7.1
Pin 4: -9.8
Pin 5: 5
Pin 6: 6.9
Pin 7: -8.5
Pin 8:9.8
Old 5th May 2011, 12:45 PM   #8
It appears to be in over-current protection. Are you sure that there are no shorted output transistors?
Do you read 0 ohms across R160 (large SMD resistor on the corner of the board)?
If yes to both of these, post the voltage on U18.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Old 5th May 2011, 03:28 PM   #9
stoke's Avatar
yes i read 0ohms on r160
U18.
Pin 1: 0
Pin 2: 0
Pin 3: 0
Pin 4: -9.7
Pin 5: -0.5
Pin 6: 0.5
Pin 7: 8.5
Pin 8:9.8
Old 5th May 2011, 05:58 PM   #10
Rockford Fosgate BD15001 seankane Car Audio 62 9th May 2011 07:55 AM
Rockford Fosgate BD15001 stuck in protect seankane Car Audio 34 1st April 2011 08:11 PM
Rockford Fosgate BD15001 seankane Car Audio 70 1st April 2011 04:22 AM
NOISE on audio system (Rockford 500a2, Sony xec1000, rockford PA2) stoke Car Audio 6 1st October 2010 10:21 PM
rockford fosgate bd15001 mike49504 Car Audio 263 6th March 2010 06:52 AM
Page generated in 0.10683 seconds (81.00% PHP - 19.00% MySQL) with 10 queries
