Go Back   Home > Forums > General Interest > Car Audio
Old 4th May 2011, 05:31 PM   #1
timwebb is offline timwebb  United States
Default quick question
ok im working on another memphis 1000d. the problem is i just replaced the op amps and one side of the outputs looks like this. when i put one in it flips like this.
Old 4th May 2011, 06:11 PM   #2
never mind! i got it.
Old 5th May 2011, 04:01 AM   #3
ok i gota rockford 1500. i found the shorted outputs.but anything i should check on this amp?
Old 5th May 2011, 04:05 AM   #4
Have you replaced the outputs yet?
There are 2 groups of FETs (leg 3 of all transistors directly connected in each group). Did FETs fail in both groups?
Old 5th May 2011, 04:21 AM   #5
no, and all the outputs failed.
Old 5th May 2011, 04:29 AM   #6
Since all of the outputs have failed, remove all of them and check the drive signal on the gate pads for both groups of FETs. To check the group nearest the RCA jacks, you may need to connect a jumper between the pad for the 3rd leg of one of the outputs (Q101) to the negative speaker terminal.
Quick question... WackiCO Car Audio 21 29th March 2007 08:38 PM
Quick quick question ! guitvinny Pass Labs 6 7th February 2007 04:20 PM
one quick question... MyNameIsJake Car Audio 0 24th December 2005 05:51 AM
quick question ... really m0nty Solid State 7 9th September 2005 02:43 PM
Page generated in 0.08271 seconds (73.33% PHP - 26.67% MySQL) with 11 queries
