I picked this amp up locally for cheap in the hopes i could fix it. Ive powered it up, light comes on, but no sound. Im getting 13.8 volts at the B+ and remote terminals. Not sure if this matters or if its normal for the amp but when it powers up and sutss off theres a clicking sound. Looking inside it appears to have no damage, whats the first place to look or test? Thanks
#2 |
The BAMF 5500/1D has relays which click. Is that the model you have?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Yeah, forgot the D on the end, i apologize. So what do i check first and thanks again
#4 |
Do you have a scope?
#5 |
Negative. I saw one the other day at a pawn shop, its a BK Precision for $60. Not sure i wanna buy one from a pawn shop though. Are scopes the best way to check them? Thanks
I actually found the same one on ebay, B&K Precision 30MHZ Dual Trace Oscilloscope | eBay Last edited by radwilsons5803; 5th May 2011 at 03:23 AM. |
#6 |
Most pawn shops offer a 30 day warranty.
A scope makes it easier to check a lot of things. Do the relays look melted? They often melt on the area shown in the attached image when the contacts fail.
#7 |
Ill throw an offer at them this weekend and see what comes of it. The two relays look good in this amp. Anything else i should look at? Thanks
#8 |
If you're going to try to get that scope, let's wait until you get it to do anything else.
Have you made sure that all of the small boards are fully seated on their connectors?
#9 |
I have not, ill do that right now! If not ill get back to you when ive gotten the scope, thank you
#10 |
They are fully seated and still no output. Hopefullly getting the scope tomorrow or monday, thanks
| Power Acoustik G540-2 | mike49504 | Car Audio | 1 | 26th April 2011 02:34 AM |
| Power Acoustik A2400db | timwebb | Car Audio | 7 | 18th April 2011 07:13 AM |
| Power Acoustik TS980 sparks, blows fuses even without power on. | BoeroBoy | Car Audio | 7 | 30th September 2010 02:17 PM |
| Power acoustik schematic | brandes.cm | Car Audio | 11 | 21st January 2010 11:15 AM |
| Power Acoustik Amp | chadrock | Car Audio | 28 | 19th March 2008 05:37 AM |
| Page generated in 0.09631 seconds (76.45% PHP - 23.55% MySQL) with 11 queries |
